Question about Whirlpool Dryers
Whirlpool dryer i replaced the thermal fuse. and it worked for about 2 loads and then it just stopped. when i went to turn it back on and the start button made a buzzing sound. i took the back off and watched as pushed it again. there was some purple and blue sparks. so i bought a new push to start switch. well it worked for only a minute. so please advise me on this matter. do you think i should take to dump ????? thank you, lori from pa
    Sergeant:
  • 409 Answers
Hi lori,
may i ask why you replaced the thermal fuse?
i would check my venting first. that is one of the most common cause of dryers stopping during operation.
do you get any error messages? if you do, it's most likely during overheating.
the reason the start button is buzzing and sparking is the fact that you are shorting the circuit.
can you supply me with the brand and model # please and i will find more information for you.
thanks again.
Posted on Sep 26, 2008
My Estate by Whirlpool dryer stopped working on 2nd load of day. Push start button doesn't do anything. Power is fine to dryer. Is there an in-line fuse or something that would have been tripped...
Yes indeed the dryer has a thermal fuse that not only could go out between cycles it could also mid cycle and leave ya with a partially dry load and a dead dryer, that is one of two parts that could be your trouble the other is the door switch, open the door and see if their is a little finger on the top right corner of the front panel inside of the door area, if not it has snapped of and the switch needs to be replaced,if its intact the thermal fuse is the problem
I have included links for youtube videos showing you how to replace the thermal fuse and the door switch
http://youtu.be/aUQQJAxkZ0g thermal fuse video
http://youtu.be/gWQhuQXa6d0 door switch video
Jul 26, 2011 | Dryers
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    I have an LER 5636 that will not start. Was working normally then just stopped working. Belt is still intact. Where are the fuses located? Could this be the problem?
    First turn the breaker off and on and try to start it. The breaker could be half tripped. If it doesn't there is a thermal fuse on the back. Unplug the cord. Take off the back cover (9) screws. On the exhaust housing there is a white oblong thermal fuse, at about a 45 degree angle, with 2 wires, held in by a screw, part number 3392519, ( about $14.99). Take the wires off and ohm the fuse, it should have continuity. Or you can take the wires off and hook them together (to bypass the fuse), Plug the dryer back in, try to start it. If it starts replace the thermal fuse.
    Feb 04, 2010 | Whirlpool LER5636P Electric Dryer
    Whirlpool electric dryer will not start
    should be on back behind rear panel on the duct assmebly
    Aug 15, 2009 | Whirlpool Dryers
    My dryer stopped working. Dryed a load of clothes
    Check the door switch. A little lever sticking down through top rightof door opening. If it is not there you will need new doorswitch(sometimes the little lever breaks off). If it is there and doesnot click when you press it in you need a new door switch. if it clicksand clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuseis an oblong white plastic piece with 2 wires attached.
    Door switch part number 3406109
    Thermal fuse part number 3392519
    May 17, 2009 | Whirlpool Dryers
    Dryer stopped working... wont turn on
    Before starting troubleshooting-Unplug the dryer, because you will be removing front panel for this check.
    There are several things that can cause your problem:
    #1 of which is a clogged up lint trap and/or vent duct raising the heat that could cause your thermal fuse to open (blow). What to do: Make sure that duct and vent outside of wall are clear, if they were obstructed, then the thermal fuse can be checked for continuity with an ohm meter, it is located in the fan housing with 2 terminals coming off of it, if it does not have continuity (connection) between terminals, you will need to replace it, simple and less than $15 bucks.
    NOTE: this problem can also be caused by a bad thermostat letting dryer get to hot which in turn blows the thermal fuse., sooo after changing thermal fuse you need to check that the temperature of air leaving dryer duct does not exceed 150 degrees, if it does replace the thermostat for less than $25 bucks, this maybe be what caused your problem in the first place. Good Luck!
    Apr 28, 2009 | Whirlpool Dryers
    OVERHEATING, AF CODE..... Whirlpool Cabrio WED6200SW1
    Mine is doing the same thing. Whirlpool still has it under warranty but says they won't replace it. They will only repair it. They have been out 5 times now and still not fixed. It will work one time and the clothes are scorched when I took them out. Do NOT BUY WHIRLPOOL. I think we should start a civil suit against Whirlpool for replacement of all of these washers.
    Apr 11, 2009 | Dryers
    Whirlpool dryer wont turn on
    Hi Joe,
    Your thermal fuse has blown. It's a cheap little part, here it is.
    To get to it, Pull the dryer out and unplug it. Remove the rear panel. As you're viewing the dryer from the rear, look just to the left of the dryer exhaust... you'll see it there. It has 2 blue wire connected to it.
    Remove the wires, remove the old fuse, install the new one, install the wires and replace the back panel.
    There ya go! FixYa! Please take a moment to rate this as "solved".
    Thanks,
    SG
    Mar 28, 2009 | Whirlpool LER5636P Electric Dryer
    LER8858EQ2 electric dryer will not come on.
    Thermal fuse on the blower housing is open. Take back off and the thermal fuse is near the blower outlet. It is white and about 2 inches long. Part number is 3392519
    Dec 12, 2008 | Whirlpool LGV4634JQ Gas Dryer
    Dryers Logo
    69 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
