maybe its not you memory card try using the usb and hook it up to your computer to see what photos you have taken or you can use the playback mode to view them and see if you took photos on accident this happend to me but i found out it left my finger on the shutter button and took lots of pics or if you have young ones around you ask if they mess with your camera
#1 MAKE SURE THAT YOU HAVE ENOUGH LIGHTING .....I KNOW BECAUSE I'VE DONE THIS. I PLUGGED THE DRIVE SIDE USB INTO THE LOCK SLOT IN BACK OF DRIVE INSTEAD OF THE CORRECT SLOT......HOPE THIS HELPS..........JEFFXC
It's definitely not Win7. The Operating system has nothing to do with it. You'd need to isolate the issue first. It should be just a plug and play device like a usb flash drive.
Try plugging the HDD to another computer. If it works, then it's a problem with the computer. If it doesn't, then you can focus on the HDD itself.
You can also try the following steps: - Try turning the computer on while the USB HDD is plugged to see if it's going to be detected. Plug it directly to the usb port and not thru a hub or extended usb cord. - Go to the device manager and remove all of the USB host controller under USB controller, which is usually the last controllers located below. Then follow the step above.
There are other things that you can do to check it but try the steps above first and let me know what happens before we go further.
if that nothing happen ..this means that you do not plugged it in a right kinda usb ...so ...change the usb and reinstall the driver it has to at least make a noise when it sees the new unit... also ...the camera needs to be powered and on ...and in the right mode...( view picks) all that done ...and still no action ...just change the cable cause its damaged... you can also use a card reader to download picturesw if the camera uses a SD card ..
I would remove the memory card and use that to transfer the media to your pc.... I can't tell you why it is not showing up on any of the pc's. The only thing I can think of is possibly the usb cord is bad or that vivicam has special software you need to download. But you can definately get the media onto to your pc by bypassing the usb cord and remove the media from the card and place it in a folder on your pc .. hope this helps... good luck
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
