Question about Brother Office Equipment & Supplies
I have window's Vista, the printer works with Window's XP, can i get it to work in Vista
  • Brother Master
  • 4,338 Answers
Did you install the Vista drivers from Brothers website?
http://www.brother-usa.com/downloads/default.aspx?ProductGroupID=1
Posted on Sep 27, 2008
Keeps on printing test page
In this case what i would request u to do is:
1. Let the Printer be Connected to the Computer......
2. Click on start then Click on Run or If Windows Vista Type Services.msc Under the Run Window if XP,Under Start Search if Vista.......
3. On that Services Local Window u need to find Print Spooler just Double Click on that and Click on Stop..........
4. Now let that Window still be Open now click on that start Menu Click on Run If XP........
Type in "Spool" and Click Ok...........
5. Double Click on Printers and Delete Each and Every File Inside the Printers Folder...........
6. Now Close this Window and now u will be back to the Print Spooler Window now u can click on Start under the Print Spooler....
Now Try to Print Will Work Fine....................
Good Luck :)
Nov 09, 2012 | Lexmark E120 Laser Printer
WE WANT WINDOWS 7 EPSON PRINTER R230X
Epson Stylus Photo R230 6 Colour Inkjet Printer files Driver Printer Driver 6.52E
Windows 2000, Windows 7, Window Vista, Windows XP Posted: 24/11/2009
Click here Utilities Epson Easy Photo Print 2.23.01
Windows 2000, Windows 7, Windows 7 64-bit Edition, Window Vista, Windows Vista 64-bit Edition, Windows XP, Windows XP 64-bit Edition EPP_22301_EHKT.exe
Posted: 19/1/2011 Download
Feb 05, 2011 | Epson STYLUS R230 InkJet Photo Printer
Problem to install printer epson stylus cx390. Problem to connect with xp to the network.
If your using the Windows Vista operating system you need also the Window Vista support driver of your printer epson stylus. If that driver is for Window XP only you just try to download at Epson for Windows Vista driver for your printer.
Oct 10, 2009 | Microsoft Windows Vista Ultimate Edition
I install the software.printer is works,but when i want to use scan,there is on the screen ocr software mising ,install the software.on the printer scan is failed.how can i scan?thanks
In this case please insert the disk to the computer goto My Computer in XP and Computer for Vista...... There u will see a icon which says DVD RW lexmark 5600 u need to right click on it and click on explore and then click on Abby and run the setup.exe file and then try to scan it will work fine................
Good Luck
May 17, 2009 | Lexmark X5650 All-in-One InkJet Printer
Job Status Window Interface has stopped working.
The issue usually occurs if you are using windows xp drivers on a vista machine. It's strange that the error does not come up when printing from internet explorer 7.0.
There is a file on support.dell.com that you can run to remove any xp drivers and then run the vista installation file. that should take care of these error messages from the operating system.
you can copy and paste the following links to download and run the files :
Patch file to remove xp drivers:
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=224499
Driver for vista
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=203951
Feb 17, 2009 | Dell A960 All-In-One InkJet Printer
1020 PRINTER DRIVER HP
There are no drivers for fixya but I have found a workaround by some anonymous poster
Xp software&drivers will work in Vista after a little tweaking in printer properties.
1)Install the CD-Rom HP Software/Drivers that came with your Printer at the time you purchased it. These Xp software&drivers are Vista Compatible after tweaking the Printer Properties. Reboot after installing.
2)Goto Start/Printers. Right click HPLaserJet1020 then Left click Properties. An HPLaserJet Properties window should have popped up.
3)Click the Advanced Tab. Click the Print Processor button located at bottom of window.
4)Select print processor as>>>IMFPrint. Then Select Default Data Type as>>>RAW. Click OK.
5)Now return to the Main HPLaserJet Properties window and click the General Tab. On the Bottom of that window; Click the Print Test Page Button. Finished! A test page should be printing out if you adjusted the printer properties correctly. Enjoy!
optionally you may have to disable print spooling
Quote "This did not work for me until I changed the option in that same window (advanced settings) to "print directly to the printer". Spooling does not work. "
Jul 14, 2008 | Office Equipment & Supplies
Download window vista theme
If you download window vista theme for xp ,it will not work untill you install any third party software .install any 3rd party software and use the window vista theme in xp
Use the below links to download the software and have window vista theme.......
http://www.softpedia.com/get/Desktop-Enhancements/Themes/Universal-Vista-Inspirat-Brico-Pack.shtml
low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not
Regards :
dilip bagdi
Technical Associate
Apr 28, 2008 | Microsoft Windows Vista Home Premium with...
My HP Printer Deskjet 3320 is not working with Windows Vista
You can follow Hp's Installing and Configuring an Alternate Driver in Windows Vista. Click this link provided by HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00808478&lc=en&cc=us&lang=en&dlc=en&product=75035
Before you follow though with Hp's alternet driver site. Please run windows update for Vista un till no updates are left. If your printer still fails to run correctly than try HP's alternate drive.
Good luck & kind regaurds..
Mar 08, 2008 | HP DeskJet 3320 InkJet Printer
Couldn't install lexmark 8300 printer software on my window vista driver computer
Follow this link to the official Lexmark website and download the driver.
http://downloads.lexmark.com/perl/downloads/downloads.cgi
If you can't follow that link, go to www.lexmark.com. On the top menu, there is a link called "Drivers and Downloads". Click it and select your series, then your OS system, and there you go.
The drivers for Vista are finally updated.
I had the same problem for about a year... now it works fine.
-Ciao!
-Wizkid
Jan 11, 2008 | Microsoft Windows Vista Ultimate Edition
20 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
