Security code
SOURCE: security problem
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
SOURCE: Security unlock code for kenwood excelon kdc-x990
Call 1800kenwood there is a default code but you need the remote to enter it
SOURCE: what is the security code for this kenwood car
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The
procedure to enter your security code differs on various models of
Kenwood car stereos. Here are three of the more common procedures:
Type 1
During
hold the Volume UP or DOWN key for 3 seconds until the "..." display
disappears.
Enter the security code using your Kenwood remote.
Type 2
Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To
enter a letter using your Kenwood remote, press a button once for the
first letter, twice for the second letter, and three times for the
third letter -- then press the Track Up or Next Track key to send the
letter.
To send the letter 'A', press the 2 key once and then
press the Track Up key. To send the letter 'B', press the 2 key twice
and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There
is a reported bug in the security code handling of some Kenwood
stereos. In models with thie bug, the security code is stored
incorrectly. The workaround is to enter the wrong security code.
In
models with this bug, you have to decrement the third character of the
security code by one. If your security code was 1111, you would enter
your security code as 1101. If your security code was 9999, you would
enter 9989.
SOURCE: My Kenwood KDC-X493 was powered
The only way to get a override lock code you will need to contact Kenwood at the link below. They will need the model and serial # to help you more.
http://www.kenwoodusa.com/Contact/
Good Luck please accept the answer and please leave a testimonial
SOURCE: i lost my security code
Have to contact authorized kenwood dealer, they have a universal code.
