Question about Brother MFC-5840CN All-In-One InkJet Printer
My brother is the stupides brother in the hole wide world.
  • jdbrothers Oct 08, 2008
    the stupid thing tells me ink is empty, then i replace it, and it says there is not cartridge!!!
Like most inkjets, the print output of this device is hopeless and we never print from it. It is however very useful for multiple page scanning and for receiving faxes electronically, BUT if it believes there is a problem with one or more of the ink cartridges, it eventually reaches the point where it can't be used for anything - even those things that don't require printing!
So here's what you do. At the side of each of the cartridges nearest the right hand side of the machine (looking from the front) there are some ribs in the translucent plastic body of each cartridge. You need to black these out so that the magic eyes that attempt to see through the cartridges when they are in place cannot see right through. This cons the machine into believing that the cartridge is there and has ink in it. I did this with a little strip of black fabric tape on each one, but I'm sure insulating tape or possibly even masking tape would do just as well.
After doing this and lowering the cover, the machine will ask you to confirm whether each of the cartridges have been renewed. Tell it they have all been replaced.
Doing this should allow the parts of the machine that work ok to carry on working without interference from the part which probably never worked satisfactorily from the day the machine was made. (IMHO the world would be a much better place had ink let printers never been invented.) Cheers!
Posted on Aug 18, 2009
    Scholar:
  • 58 Answers
Http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/000700/000034/faq000734_005.html?reg=us&Printable=true&c=us_ot&lang=en
Date:06/13/2008 ID:faq000734_005 Print | Close
Title:
Why does my machine's LCD show "NO CARTRIDGE" even though I have already installed all the ink cartridges? Description:
An ink cartridge is not installed properly. Check that the ink cartridges are installed properly and reinstall the ink cartridge following the procedures below:
  1. Open the ink cartridge cover door.
  2. Push the 4 colored levers down to release all four ink cartridges from the machine.
  3. Each color has its own correct position to match the color of the cartridges with the color of the levers. Insert all of the ink cartridges in the direction of the arrow on the label until it clicks into place.
  4. Close the ink cartridge cover.
  5. If you replaced an ink cartridge, the LCD may ask you to verify that it was a brand new one. For example, Did You Change Black? For each new cartridge you installed, press the up navigation key or 1 or "+"(Yes). If the ink cartridge you installed is not a brand new one, be sure to press the down navigation key or 2 or "-"(No).
If you mix the colors by installing an ink cartridge in the wrong position, clean the print head several times after correcting the cartridge installation.
Once you open an ink cartridge, install it in the machine and use it up within six months of installation. Use unopened ink cartridges by the expiration date written on the cartridge package.
If you have followed this procedure and still have the same error condition, make sure you are using Brother Genuine Supplies. Generic supplies can cause this error condition.
If the problem continues after verifying the cartridges are installed correctly and that you are using Brother Genuine Supplies, then there may be a problem with the unit. Please contact the appropriate Customer Service Center.
Posted on Dec 31, 2008
  • 1 more comment
  • Gerhard Stoll
    Gerhard Stoll Dec 31, 2008
    http://answers.yahoo.com/question/index?...
    if it's error 41, you're unfortunately dead out of luck and need to either contact brother or buy a new printer :(
    if it's telling you they are empty, you can only reset that by telling
    the printer they are not empty, and then of course the printer will
    think these are full carts and will continue printing until it decides
    they are empty again (which can run the risk of burning up the print
    head carriage, and that is an expensive fix).
    if the carts are newer (say, the lc 41s or 51), there is actually a
    piece of plastic inside that lowers with the ink level. if you have
    these, you either need to refill or get new carts, or else the printer
    will keep tracking the plastic level gauge, and if your carts are close
    to empty, the gauge is at the bottom.
    i hope this made sense and helps you solve your problem.
  • Gerhard Stoll
    Brother Error #41
    Anwendern die bei unter dem Fehler #41 leiden wird des
    öfteren gesagt, dies liegt an Refill-Tinte bzw. dem Einsatz von
    kompatiblen Tintentanks. Komischer Weise sind aber auch Kunden betroffen die
    ausschliesslich Original VB-Material benutzt haben.
    Seitens eines
    Grosshändler liegt uns eine Service-Info-Schreiben zu diesem Thema
    vor.
    Siehe hier:
    Diskussionsforum-------------------------------------------------------------------------------------------
    http://www.hstt.net/forum/viewtopic.php?...
  • Gerhard Stoll
    for more look on:
Brother 2200 driver
Most of the drivers located on the brother website are in the form of an Executable setup file which goes through and sets up your printer. The INF files are there just need to unzip the file and find them in the directories if you want to set up the printer manually.
Apr 02, 2014 | Brother HL Office Equipment & Supplies
I have a brother 6000i. How do I utilize the extra spool pin?? Where does it go ?
bAttach the extra spool pin.
Put the extra spool pin in the hole on the top of
the machine. Put the second spool of thread
onto the extra spool pin.
See page 25 in owners manual.
Feb 25, 2014 | Brother CS-6000i CS6000i 60-Stitch...
What is the anwer for this question
definition - A technical definition of the World Wide Web is: all the resources and users on the Internet that are using the Hypertext Transfer Protocol (HTTP). A broader definition comes from the organization that Web inventor Tim Berners-Lee helped found, the World Wide Web Consortium (W3C): "The World Wide Web is the universe of network-accessible information, an embodiment of human knowledge."
Nov 25, 2010 | Computers & Internet
My brothers acount acspierd
yes the most STUPID STUPID thing about webkinz is that the account exspires in a year im sorry but if your brother wants another one you are going to have to buy another one
Feb 16, 2010 | Ganz Webkinz Black Lab Dog
Super mario brothers world 7
In World 7 - 4 (I think its World 7 - 6), use MINI Mario or Mini Luigi and hit bombs and throw bombs to make them explode and go to the tiny hole and ull end up somewhere  and ull beat the level and ull get to past the land to get to World 7 - 7
Mar 01, 2009 | Nintendo New Super Mario Bros. for DS
I hv toshiba l310 how to get sound driver and other driver plz tell me
Please look on the Toshiba support home page here:
http://de.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=DE
4 Gefundene Treiber Datum Typ Firma Betriebssystem Version Land Weitere Informationen 16/09/08 arrow_download.gif Sound Driver Realtek Semiconductor Corporation Windows Vista 32 Bit 6.0.1.5599 World Wide bulletarrow.gif 08/09/08 arrow_download.gif Sound Driver Realtek Semiconductor Corporation Windows XP 5.10.0.5599 World Wide bulletarrow.gif 04/06/08 arrow_download.gif Sound Driver Realtek Semiconductor Corporation Windows XP 5.10.0.5559 World Wide bulletarrow.gif 04/06/08 arrow_download.gif Sound Driver Realtek Semiconductor Corporation Windows Vista 32 Bit 6.0.1.5559 World Wide bulletarrow.gif
Dec 30, 2008 | Toshiba Satellite A205-S4617 Notebook
Unlocking my Blackjack SGH-I607
i need the unlock instructions i purchased with world wide unlock program..
Mar 26, 2008 | Samsung Blackjack SGH-I607 Smartphone
Need replacement bowl
Depends where you are. These are the guys who sell the fans in the US (Through Amazon): Direct link; http://www.antonline.com/c_0_18317_5__3268_1_50.htm Company name: ANTonline Street address: 33 Mansell Court Suite 200 Roswell, GA 30076 USA Web site: http://www.antonline.com Customer-service phone, fax, and e-mail Phone: 877-293-9797 Fax: 770-874-0789 Email: support@antonline.com Hours: 9am-6pm Mon.-Fri. EST Also the fan is Known by the "Boston Harbor" name (same model number). If you are outside the USA, please ask again. Hope this helps :) ps the Amazon list price for the whole unit is $77, so check on replacement bowl prices before ordering - if the fan is more than a few years old, it may be better to replace completely.
Aug 22, 2007 | World Wide Sourcing (CFB5521F242WH)...
Nikon d50 and lens
I don't have this kind of camera myself, but on my Canon D350 there is a switch on the lens that sets manual/automatic focus. Mine is marked MF/AF ans is just a simple switch. Check to see if this might be the case on yours, too. Also check the contactts on the lens and camera to see if they might be dirty. And be very careful not to get any dust into your camera housing! -Chris
Mar 06, 2007 | Nikon D50 Digital Camera
Brother MFC-5840CN All-In-One InkJet Printer Logo
154 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
