Hi, I have Pioneer receiver model vsx-d307-ht showing the following message in display MUTING after the function it uses 2 power IC Pac 0007A, please i'll be waiting for your soon answer...
Thanks!
Mario
Pioneer says it's internal problem. Technician said minimum 145.00 to fix. Cheaper to buy new. Hope this helps! Pioneer says it's internal problem. Technician said minimum 145.00 to fix. Cheaper to buy new. Hope this helps!
You can't post conmments that contain an email address.
No the headphone jack doesn't disable the speakers. There are two switches in the lower middle of the receiver that are labeled speaker A and B. Pushing one of these should disconnect the speakers from the receiver.
You mean Vsx 405, right? Model numbers are senseless enough without typos.
Are you saying you DON'T have a remote? How did you ever set it up? There are several CU-VSX105 remotes available on eBay, one at $9.99 and expiring in a few minutes (17:12 PDT). If you get this in time you could snipe it at the last 10 seconds.
Many a Pioneer receiver will come up MUTING if it powered down Muting. It's not clear if you have been experiencing unwanted shut-downs. Unwanted Muting or any other command could well originate with an unintended remote control source. Mask the receiver so it can't see other I/R sources.
I'd suspect a wild remote control or other I/R source in the area. Hide all the known remotes and block the I/R eyeball on the front of the receiver and see if it still happens.
