Question about Samsung ML-2510 Laser Printer
Paper draw Paper does not draw into printer
  • 3 Answers
Check if the rubber draw rollers are pressing the paper down properly.
If this is okay then see what is the default thickness of paper that has been configured .
Similar problem had happened when my friend had printed a whole stack on photo paper and set the thickness of paper to highest level to ensure paper is not stuck inside, later it would not draw in normal thicknes paper till we rest the paper settings.
Posted on Sep 26, 2008
J01 error when printing from d
Are sure the paper in the draw is in the same orientation as you are selecting on you computer in the print properties landscape in in draw and portrait on the computer will not work or vice a versa. Using bypass tray or paper draw? Check the guides in each draw snug up against the paper?
Jun 01, 2014 | Minolta Di152 Laser Printer
How do i clear the error code c0910?
Second draw lift ensure no PAPER is in the back of the draw jammed between draw and back of copier. Also check the no paper is being stored in side the draw all paper is the right side of the draw DO STORE EXTRA PAPER IN THE DRAW NOT DESIGNED FOR it
May 21, 2014 | Minolta Di3010 Copier
Bizbub c352 malfunction detected c0206
open all the draws and check to ensure no paper behind them install the paper properly in the draw DO NOT STORE PAPER ON THE LEFT SIDE OF THE DRAWS ITS NOT A STORAGE AREA IT IS FOR 11 x 17 PAPER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Worse case you blew out the draw motor and main board?
Apr 10, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Error Code C0920
Remove the first draw and check to ensure no paper behind the draw SECOND REMOVE THE ACCESS PAPER FROM the draw the left side of the draw is not for storing extra paper the space is available for when the draw is set to 11x17 paper DO NOT STORE EXTRA PAPER THERE.
Mar 14, 2014 | Minolta Di3010f Printer
C0920 copier code
First paper draw lift open the draw check behind it ensure no paper stuck back there. REMOVE any STORED EXTRA paper from the draw the extra space is not for paper but if you decide to put 11x17 paper in the draw you need the space.
Feb 07, 2014 | Minolta DI2510 Black and White Copier
Bizhub 211 error code 211
Check behind the paper draws for any paper jammed back there . ALSO DO NOT STORE EXTRA PAPER in the draws that extra space is for if the draw is set up for 11x17 paper!!!!!!
Jan 14, 2014 | Minolta Office Equipment & Supplies
I can not get the printer to print at all - it appears to not be drawing the paper i. I also can't find a driver for my wife's macbook pro despite the fact that it was a free printer with the machine
It's your printer fail to draw paper or it can't print at all. If it fails to draw paper, try reloading the paper nicely on the tray. Sometimes the printer can't detect paper or else it must be the problem with the paper roller. If neither the case, open up the printer cover and see if any pieces of paper jammed in there. It won't work it there is.
You can get the driver for mac here: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=15402#DownloadDetailAct
Mar 20, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Close drawer...
Take paper draw out of the machine you mite have paper behind the draw preventing sensor monitoring that draw from working properly. Mite get some can air an get any paper dust off the sensor for that draw. Is paper properly installed and are the paper guides securing the paper properly installed? Don't be storing additional paper in the draws. Is paper in the draw matching what is on the operators panel.
Aug 15, 2009 | Toshiba 2060 Copier
C0910 code im3520 imagistics copier
Your lift motor, for second paper tray draw, or third draw, are you storing extra paper in the second or third draw, beside the paper properly placed in the draw. Is there paper behind the draw? Do not store extra paper in a paper draw. Just because the draw has space not setup for 11x17 paper and is being used for 81/2x11 dont store extra paper. If this is a large capacity tray for over 500 sheets paper can only be set up for 81/2x11 protrait not landscape.
Aug 06, 2009 | Office Equipment & Supplies
Samsung ML-2510 Laser Printer Logo
109 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
