Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Kenmore elite range oven problems
We converted our kenmore elite range to propane a year ago. Recently my oven will not cook above 350 degrees anything higher and the oven just will not work. At first it would work sometimes and then sometimes it wouldn't. please help.
  • 1 more comment
  • ants_2you Sep 30, 2008
    i will check that thanks. I was wandering if it might be because i am low on propane. But the rest of the stove is working good.
  • boivin_robin Jan 04, 2009
    I have the same problem when I go above 350. But my Kenmore Elite is electric and I think that's the electronic module that resets once in a while for no reason. To go to 450 degrees, I might have to cancel and restart many times. Is there an easy way to replace electronics in the Kenmore elite?
  • Anonymous Mar 17, 2014
    Kenmore Range Oven not working
  • 943 Answers
Hi. thanks for the question . i would replace the igniter in oven .thanks the appliance doc
Posted on Sep 30, 2008
  • john gagnon
    john gagnon Sep 30, 2008
    hi YES i would replace the igniter low propane would not cause your problem thanks the appliance doc
Oven temp fluctuates
It is normal for the thermal device to turn on and off. Obtaining a steady temp is not always possible. When setting a temperature on some ovens, they have what is called a tolerance point. That means a set temperature has a range of a few degrees up or down. At the Down point, the oven is triggered to energize the coils and bring the interior of the oven back to the settings desired. The other factor is opening the oven and allowing cool air to enter, or in some cases a leaking door seal allows air to enter and heat to escape.
Feb 26, 2014 | Kenmore 30" Slide-In Electric Range...
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
I have a Sears Kenmore Elite 790 hooked up to propane .. is it ok to have it hooked up to propane or is this over for natural gas only?
Kenmore Gas ranges can be used with Natural gas or Lp. They come from the factory set up for Natural gas so if you want to use Lp it needs to be converted by you or your gas company. There are several adjustments that have to be made and some ranges require orifices to be changed. Your installation manual tells how to convert it but if you're not sure about doing it you would be better off the call the gas man.
Aug 28, 2011 | Ovens
My Kenmore oven won't work there is a PF 5AB error
The PF on your control indicates a power failure and should be removed by pressing the cancel button. The 5ab code indicates the range is in the SABBATH mode.
If a power failure occurs when the SABBATH mode is set, the oven will return to the OFF mode and will turn the power OFF to the oven.
To ENABLE SABBATH mode:
* Open the oven door
* Press STOP/CLEAR
* Press both the HOUR "UP" and "DOWN" arrow pad at the same time - and hold for 5 seconds.
SAB ON will disappear from the display.
To disable SABBATH mode: Repeat the steps above and SAB OFF will appear.
To set the SABBATH mode for use during the SABBATH/Holidays:
* Press BAKE
* Pres TEMP "UP" and "DOWN" Arrow pad to enter a different temperature other than 350 degrees. (Between 170F and 500F)
* Press COOK TIME
* Press HOUR/MIN "up" or "down" arrow to set cook time
* Press DELAY START to set a delayed cook time (optional)
* Press and hold TIMER OFF for 5 seconds
SAB will appear on the display indicating it is ready.
* Press START
* To STOP cooking - press STOP/CLEAR
* To exit the SABBATH mode and return to normal operation - press and hold TIMER OFF for 5 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 05, 2010 | Kenmore 71414 / 71419 / 71410 / 71412 Gas...
Stuck at 288 degrees
NO PARTS REQUIRED!!! DON'T PAY FOR A SERVICE CALL!!!
After a power outage, my wife's grandmother said she could no longer set her over to 300, 400, 450, whatever..
I went over to troubleshoot.
I couldn't figure out why everything seemed functional and why I couldn't set the over to higher than 288 (and thought, that's a rather odd number)... until I realized that that 288 degrees C = 550 degrees F which is the max the oven can do.
The power outage reset the computed back to celcius instead of fahrenheit.
Save them a ton of money... cause this could have been an easy cash grab to some cook out there.
May 01, 2009 | Kenmore Kitchen Ranges
KGST307 gas stove has a temperature control problem.
the least expensive fix would be to buy an oven thermometer and note what setting is needed to attain 350 degrees and go from there. please rate me
Jan 06, 2009 | KitchenAid KGST307 Gas Kitchen Range
Oven over heats/gas smell
Hi the fact that you smell gas near the floor suggests you do indeed have a gas leak, propane is heavier than air to will fall to the floor.
you really need to get the gas company to check
Mar 14, 2017 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Kenmore Elite Range/Oven problem.
We had this problem as well, our's locked and we were not able to unlock it.
We found that holding down the stop/clear button on he bottom right of the key pad for 3 consecutive seconds releases the lock.
The locked oven wording will blink for about a minute and then the oven is released completely.
So frustrating...I accidently hit the option while cooking. Talk about panic. I needed to use the oven.
Jun 25, 2008 | Kitchen Ranges
Frigidaire fgf316wgsh
Is it natural gas or propane? They usually come as natural gas. If it is propane has it ever been converted? If not convert it.
Nov 30, 2007 | Frigidaire FGF316 Gas Kitchen Range
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
616 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
