Question about Pioneer SD-643HD5 64" Rear Projection Television
Way too dark
My pioneer sd-643hd5 screen is really dark, it happened just all of a sudden, one second it was fine next its was really dark
    Problem Solver:
  • 7 Answers
Besides being dark, are the colors inaccurate? If so, I bet one of your CRT's (Red, Green, or Blue) is out. When my green CRT went out, my picture was very dark and the colors were inaccurate (e.g. no green at all). My problem was caused by a bad solder connection on my Green CRT driver board which I fixed with the following procedure.
1) Determine which CRT is out (red, green, or blue)
2) Unplug your TV
3) Locate the Driver Board attached to the bottom of that CRT.
4) Locate the two large metal heatsinks on the driver board. Each has a transistor attached to it.
5) Carefully touchup the solder connections on each transistor (on the underside of the circuit board). I added some additional solder to help reflow the solder onto the pad of the circuit board. It's a bit tricky because the solder has to fill a large gap between the small leads of the transistor and large holes in the circuit board.
(If the above does not make sense, then it's best to leave the repair to a professional)
Posted on Sep 30, 2008
  • 4,234 Answers
This can occur because of a component failure. A reset is not likely to fix this. One thing you can try or at least observe, is whether or not this recovers once the set has cooled down. It is possible that there are aone or more bad solder connections inside that are causing this. Please update this if you can.
Thanks,
Dan
  • 2,071 Answers
Resetting the TV
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards,
VOTIT
Posted on Sep 26, 2008
Tell me how to clean my bulbs and mirror of my pioneer SD-643HD5
You will have to remove the Front Screen ,First remove the bottom Panel and then the screen.
Jun 29, 2011 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer 65" TV Model # SD-643HD5 won't power up.
I would suggest replacing the board itself, chances are what caused those fuses to blow is still faulty. did you check those fuses again after you powered it back up?
Jun 12, 2011 | Pioneer Televison & Video
I have a Pioneer SD-643HD5 that was working and then just turned off? Now the tv won't turn on
CK for Blowed Fuse will be in middle of chassis 6amp fuse if it is blowed set will not come on.
Dec 30, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Convergence board cracked?
Once the board is cracked it is no longer repairable (even if it's a tiny crack that may not appear to interrupt any connections), and you would have to replace the complete board. Any attempt to repair or continue using a cracked board may cause more damage to the entire unit. You can find a replacement digital convergence board for a model # SD-643HD5 from this major Pioneer parts distributor at the following link:
Pioneer SD-643HD5 Replacement Part Digital Convergence Board
Feb 02, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Where do i find convergence chips for a pioneer sd-643hd5
Complete convergence assy is available in Part Store for $126
Pioneer Parts has same CONVERGENCE ASSY for $288
Jan 25, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer sd-643hd5
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Nov 03, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer SD-643HD5 does not power on
i had the same problem and it was the flyback transformer on the power supply board.it cost me $375 for the board.just make sure you ground yourself because the static electricity could fry it all.when unplugging the cables mark them and be careful.use a jewlers flat head scewdriver to unlock the cables.use a can of compressed air to clean off the dust.
Aug 26, 2007 | Pioneer SD-643HD5 64" Rear Projection...
HELP TO FIND IC's CONVERGENCE GENERIC NUMBERS
STK392-180 http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Aug 01, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer SD-643HD5 64 in. Rear Projection
You need to replace convergence chips - they are behind the large black heatsink
May 22, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer SD-643HD5 64" Rear Projection Television Logo
126 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
