I used more then 10 GB . can i know how ? - Computers & Internet
  • navidh
    navidh May 11, 2010
    have you used more than 10 GB of your hard disk drive???
  • 68 Answers
Andreabetter.
Ok, Im making an assumption here that you are using a windows based operating system so..
10GB isnt a great deal, your operating system and subsequent patches or service packs could take several Gigabytes and your programs folder will take several more.
Add onto that any temp files, browsing history etc theres another chunk gone.
Then theres your profile folder which holds details about you on the computer and your My Documents folder this is going to take another slice of the pie.
Hope this helps.
ElApe
Posted on Sep 26, 2008
TPLink TG-3269 V3.2 not in gigabit speed although driver is updated
Did you make sure you that
  1. Your router LAN port supports GB Ethernet?
  2. You are using at least CAT5 cable? Try 5e or 6 if you have one. I've seen issues with older cables, where only 4 pairs where punched through (GB needs all 8 pairs)
  3. you checked the settings on the TPlink (especially Autonegotiation?)
let me know
Dec 02, 2012 | TP-LINK Gigabit Lan Card (10/100/1000)...
What is the fuel capacity of the Briggs and Stratton 5550 watt generator and what type of motor oil does it neet?
Hello, probably a really good guess is 2 1/2 to 3 gals. Oil type I would use cleaing additive multi-temperatur 10/15 or 10/20 well know brank. Synethic oil I don't know how well does it work in an air cool engine. GB...stewbison
Aug 23, 2011 | Briggs & Stratton Power Products 5,550...
I try to copy form computer to hard drive with 6-8 GB flle. But it shows the message " The file size is too big to copy" So how can I copy over 8 GB between computer and External Hardrive? thank you
This is most likely a result of the drive being formatted in FAT32. This formatting option is highly compatible and can be moved between Mac, PC and Linux with ease but lacks the robustness of NTFS, EX? or the newer Macintosh formatting options. One of the things it lacks is the ability to handle files larger than 2GB.
I can walk you through the steps of converting the drive to a newer file format but I need to know what operating system you are using. Please reply with either Mac 10.? or Windows ??? where the question mark is a number or name of the specific version you're using such as OS 10.4 or 10.6 in Mac or windows XP or 7.
I can help you with either but need to know which instructions you require.
Sep 21, 2010 | Western Digital My Book Essential Edition...
How to add free disk space in hard drive?
Use a bootable CD and use partition magic 8.2 program for this purpose. You can change any desired format without data loss and also resize without any data loss. It will work 100% and guranateed beter work.
Good Luck
Dec 01, 2009 | Computers & Internet
How to change hard drive partition?
open link download software install it and after that change partition size ....
http://hotfile.com/dl/14620860/ca808b7/Parition.Magic.8.0.rar.html
enjoy it ........
Nov 30, 2009 | Microsoft Windows XP Professional
21/10/09 Hallo. Re.: hp Omnibook XE2. Upgrade hard disk drive 20 GB or 30 Gb. I would like to know if some one has installed a 20 GB or 32GB hdd and if he has any problems with that. I would like also to...
the HDD best to use is an SSD.
the HDD was a standard, 2.5? PATA drive for laptops
why would you want such a small drive, they dont make them now. (40 smallest?) new.
this PC is not supported by HP now, its too old a Pentium III no less.
why would 20gb be and upgrade.?? 10 now? omg , it is 10GB...then... and worse its PATA (IDE) harddrive.
its 17 years old now, most are in the recycle bin,
it came with windows 95 or 98, (hopeless that OS)
the laptop has zero value now, so is putting a new
$50 to 100 dollar drive,is wise,?
what if there are more problems, (endless when that old)
you can not use modern, SATA drive (
just 2.5" PATA (IDE) (pata is wide parallel interface with wide ribbon cable)
here are some
http://www.pricewatch.com/price/hard_removable_drives/notebook_40gb
Jul 18, 2017 | HP 80GB NOTEBOOK HARD DRIVE KIT FOR HP...
Cpu usage nearly 100%
check in your task manager whats the service which is using your cpu usage and let me know
Mar 24, 2009 | Intel DG31PR Motherboard
Coppying speed is slow
in vista you need to change the remote differential compression.  Can be found in control panel?programs?windows settings I believe.  Turn it off.  As far as XP, sounds like a problem with the hard drive or memory.  I know of this issue in vista, but never ran into it with XP.
Mar 06, 2009 | Computers & Internet
Error message on E260 player
Same problem delete a couple of songs up to 6 mg or 10 whatever then allow to refresh then download your songs back in the music file. the sansa needs some memory to know it has the sdcard in it...
Dec 28, 2008 | SanDisk Sansa e260 MP3 Player
Drive C, full
Save all your files, your disk is risking to collapse at any time.
You cannot efficently run Vista on a 10 GB hard disk.
Minim efficient size it will be 40 GB or so.
Delete as many useless files as you can, use the hard drive cleaning tool that you find under all programs/accessories/system tools.
To save your file you can use the backup option in control panel, and save all files to an external USB stick or external hard drive or, do not use CD RW because the disk is full and there will be no space for disk image on hard drive.
If you want to keep using Vista I suggest replacing the hard drive for a bigger one.
Sep 05, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
