Question about Canon imageCLASS MF4150 All-In-One Laser Printer
Printer uses too much toner - Canon imageCLASS MF4150 All-In-One Laser Printer
  • 505 Answers
Need to change the quality of the printout. yIf its set to Best quality it will use more toner. Change the print quality to Normal by going to the printing preferences tab.
Posted on Oct 07, 2008
Dell printer 1250c , printer in Error state
The indicators provide information on the status of the printer and help you locate each problem. Following are the Indicator Status Condition and what they signify.
  • Jam Orange on A paper jam occurred.
  • Orange blinks The rear cover is open.
  • Toner Orange on The specified toner cartridge is empty or not installed when Dell toner cartridges are used (Non-Dell Toner is set to Off).
  • Orange blinks The specified toner is low when Dell toner cartridges are used (Non-Dell Toner is set to Off).
  • All toner indicators blink when the printer is in the non-Dell toner mode (Non-Dell Toner is set to On).
  • Error Orange on A fatal error occurred.
  • Orange blinks An error occurred.
  • Ready/Data Green on The printer is ready to print.
  • Green blinks The printer is processing or printing.
  • Orange on The printer is in the power saver mode.
  • Orange blinks The printer is canceling.
  • Start Green on To continue printing, press the (Start) button.
  • Cancel - To cancel the current job or clear the error, press the (Cancel) button.
For detailed information, please click on the link below for Manuals & Documents for the Dell Printer 1250C. Check Chapter 11 - Page 69 to 77.
Feb 24, 2017 | Dell Office Equipment & Supplies
Put in new toner still says toner needs replacement ? Using original Brother toner?
Brother says a standard toner cartridge will print about 3500 pages ... Things You'll Need: Replacement toner cartridge; Piece of paper ... Turn off the printer and allow it to cool for at least 15 minutes, if you have been using it recently. ... Put the new toner cartridge in the printer same way the old toner ...
Jul 20, 2010 | Brother MFC-7220 All-In-One Laser Printer
Reset printer
The toner cartridges for the 8026 have a chip on them which count the amount of toner being dispensed from the toner cartridge.
When the printer counts the amount of toner being dispatched from the cartridge has exceeded the amount of "usable" toner in the cartridge, the printer will display the error showing the toner cartridge needs to be replaced.
Crucial the printer also "writes" to the chip on the toner cartridge to say it is empty----You can no longer use this cartridge by simply refilling it.
You need to replace the toner cartridge on the printer with a Genuine New 8026 toner, this should then clear the error automatically and the printer will again spring back to life.
If you are using a new toner you may;
  1. Have a faulty replacement toner
  2. Have a blockage in the pipe which takes the toner from the toner cartridge to the drum unit
  3. Have a fault with the toner dispense motor
Jul 20, 2010 | TallyGenicom 8026DN Laser Printer
Error code"toner exhausted" what to do?in samsung scx 4300
toner exhausted = the toner has been used all up, buy a new one.
It's something like
May 27, 2010 | Samsung SCX-4300 Monochrome Laser...
Compatible toner is more cheaper than original, risking quality and due to low quality of the powder you can damage your printer.
I suggest to use original toner and at the printer properties set your printer to work in save toner mode.
Sep 30, 2009 | Brother HL-2040 Laser Printer
1332 infoprint printer not supporting 1332 toner cartridge
If the toner in the machine is NOT MIRC it will not work in a MIRC printer. Get the correct toner cartridge or get a NON MICR printer to put your toner in. MICR uses a special toner (magnetic) for printing checks and the printer is usually modified at the factory (troy or others) to make it print using MICR toner. No way around it.
Aug 14, 2009 | IBM Infoprint 1332 Laser Printer
Printer ink
You can use refilled toner cartridges or off-brand compatible toner. The plus side to this is they are far cheaper and they do work. The down side is that they may increase wear on your printer and if they are the cause of a printer malfunction your Dell warranty is not required to fix the problem. It's a calculated risk--one which I personally take (three or four replacements of toner save enough to buy a new printer).
May 05, 2009 | Dell 5110cn Laser Printer
Toner Saver.
Using the Toner Save Mode
The Toner Save mode allows the printer to use less toner on
each page. Selecting this option will extend the life of your toner
cartridge and reduce your cost per page, but will reduce print
There are two ways to enable the Toner Save mode:
From the Control Panel
Press the Cancel button on the control panel. The printer must
be in Ready mode (On Line/Error green LED is on).
• If the Toner Save LED is on, the mode is enabled and the
printer uses less toner to print a page.
• If the Toner Save LED is off, the mode is disabled and the
printer prints in the normal mode.
From the Printer Properties
You can also enable the Toner Save mode in the Graphic tab of
the printer properties. For details, see Software User’s Guide.
Jun 30, 2008 | Samsung ML 2010 Laser Printer
Toner empty error while toner is not empty, cannot print any document, system data can be print through the printer
toner empty replace toner with without reset chip
i want window file printer start without reset chip run printer
i am all ready use ml1640,ml2245 printer file use
Dec 04, 2007 | Samsung SCX 4200 All-In-One Laser Printer
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
49 people viewed this question
old marine
old marine
