Question about Fujitsu Siemens AMILO Pro V7010 Notebook
How do i open up the casing
I have taken out all the screws but there seems to be somthing holding the back of the casing
There are two ribbons holding the sections together. One is for the keyboard and one for the touchpad. They are hard work top get connected afterwards so expect some servere cursing .I found that asking my friend to do it with some forceps did the job admirably.
Posted on Feb 26, 2009
My n4030 dell cooling fan is stoped and before that it was very laod amd noisy so i want to open cover may be ther is somthing is blowin it up
The good news is that you will get to open that case.The bad news is you will open the case to replace that fan.
Remove the power cord.Then open the case.Make sure you do NOT do this while standing on carpet or a rug.Before you touch anything make sure to touch some one or some thing to discharge static electricity.Now use a small screw driver and remove the 4 screws that hold the fan down.Now gently lift the fan out and put in the new one.Screw it down not to tight or it breaks the fan.Put the case together and you are done.
May 16, 2011 | Dell (6F858) Cooling Fan
Gateway dx4320. want to install sata card. have side panel off but the metal tab for the card opening is not screwed in like older computers but seem to still be attached by small connections to the rear...
I found a picture of the rear of the case and it looks as if there's 2 screw that hold the right side of the case on, if you're looking at the back of the case.
I really wish manufacturers would put thumb screws on the cases instead of actual screws.
Mar 16, 2011 | Gateway DX4320-45 (99802063979) PC Desktop
How to remove dvd from gateway nv54
If you are asking about removing the dvd device itself, on the bottom of the case there will be a single screw that holds the drive in place in the case. This screw is marked by a circle with a small wedge taken out. Remove this screw, not turn the laptop back over and with a paperclip, open the paperclip and stick one end in the black hole on the door or bezel of the dvd player, this is an emergency eject button. When the tray pops out, pull the tray and the rest of the drive will follow.
Sep 27, 2009 | Gateway Computers & Internet
How do I remove Frigidaire FMV156DCC under cabinet microwave?
Underneath the microwave, on the right & left hand corner sides at the back, there are levers that you pull down & it releases the mounting bracket.
Jun 25, 2009 | Frigidaire FMV156DC Microwave Oven
My maytag top loading washing maching only fills up with water
take the two screws out of back controll panel than jam somthing to hold the door closed switch forward mine did same many times and it is always that switch moved back a little to far you can check by holding open door and push in switch with a pen or somthing
Apr 01, 2009 | Washing Machines
Cannot get into tomtom one v3
After the screws are out, just put something (I used a fingernail, but you might want to use something like a butterknife or a thin bladed screwdriver) between the silver front casing and the black back casing at the top front corner. Then gently pry until it separates. Do the same thing for the other top corner and the case should just pull loose. Be careful not to stress the cables connecting the speaker and the battery by pulling the back casing more than a few inches from the front casing (the battery and the speaker are attached to the back casing). The battery is held in place with sticky tape. Just disconnect the cable and gently pry it free from the sticky tape.
Mar 19, 2009 | Tomtom ONE 3rd Edition GPS
How to open ps2 cover
there is a screw under the warranty sticker
Jan 20, 2009 | Sony PlayStation 2 (PS2) Console
How do i open the 300gl box
Opening the case is a breeze; remove three large thumbscrews, and you're in.
Jun 01, 2008 | IBM PC 300GL PC Desktop
Computers & Internet Logo
274 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
