Blue people how do i index the color wheel
  • schisesi Sep 27, 2008
  • 8,617 Answers
Its done by entering the service menu. The proceedure should be outlined in the service manual. If you dont have one I suggest you get one before attempting the adjustment as the service menu shouldnt be enterd without having the service manual. You can get a service manual st the following link for your model.
Posted on Sep 26, 2008
Samsung HLR5078 50" tv - replaced a shattered color wheel but the colors are way off with the new one - yellow in place of both red and greens.
I'm not sure you received the correct color wheel. Do you have anything left of the shattered color wheel to compare it to the new one? Seems if you got the correct wheel then the colors should of been the same. Color wheels spin at the same rate of 60Hz. The only reason why you would get the wrong color is that the color on the wheel is in the wrong placed at the right time. I would see if you can get a wheel the same # as your original one.
Nov 11, 2014 | Samsung Bp96-01103a Dlp Tv Color Wheel L6...
Samsung HLP4663w. After replacing the Ballast, Bulb and Color Wheel (color wheel came without the CCA values and the Actuator and Index delay values) we still have the same color and picture problems. Do...
if the picture is blue green there is a jumper to be removed on the dmd board on connector cn810--the index delay should be between 40 and 50 for optimum color --or adjusted for best flesh tone also in the options the cw setting should be set for cw2
Feb 06, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
After color wheel replacement colors are wrong
you need to index the color wheel after repalcing it so its spinning at the correct speed
Apr 30, 2009 | Televison & Video
New Color Wheel not the same as original part which is 7 segment
you got sent the wrong color wheel, You will definatly need a 7 segment whhel for your model.Your color index will be off with the 6 segment wheel and you wont be able to index it correctly
Apr 02, 2009 | Samsung HLN617W 61" Rear Projection HDTV
People on tv are blue
you will need to index the color wheel in order for it to have the correct tints
Sep 26, 2008 | Samsung HLP6163W 61" Rear Projection...
Buzzing noise from lamp area.
if your model is the HDLP50W151 your color wheel is 212.00 at the following link and they provide free instalation instructions and also free tech support to help you with the Indexing when your finished as all color wheels in RCA TVs have to be indexed after instalation. You need color wheel 212184 heres the link
Click on the color wheel catagory on the left column.
Jun 26, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
RCA DLP color wheel issue
The color wheel is a straight forward installation the indexing is where most people have the trouble as the color wheel needs to be indexed properly after instalation or the tints will be off. I always recomend that anyone needing to replace the color wheel go to this following link as they have the DLP service manuals which will help you get the set apart without harming anything and the site will provide free tech support to actually take you step by step with the replacement as well as the indexing proceedure by on line instant message and thats all free when you purchase the service manual which they email to you right after ordering. Is a very good deal as it makes the job easier and you will always have the manual and free tech support even for other models when you become one of their customers. Heres the link.
May 17, 2008 | Televison & Video
You need to index the color wheel
May 11, 2008 | Samsung HLN617W 61" Rear Projection HDTV
The jumper that you need to remove is a small usually black block of plastic approx 1/4" in across and 1/8" thick located near the center of the shiny silver colored apparatus into which the color wheel is plugged. Mine had a label that read FDB Bearing Color Wheel, BP67-00099A and two illustrations indicating open and shorted conditions. The label was just over the jumper. I pulled it out with needle nose pliers and the problem was solved. GndLoop
Mar 18, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
I have found that this color wheel comes with a set of instructions that includes getting into the service menu and setting the index for the new color wheel. If the instructions were not with the color wheel, you will need the DVD for this model to find the information on entering the service menu and setting up the color wheel.
Jan 04, 2008 | RCA HD50LPW175 50" HDTV
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
