Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Repair for flashing timer light.
THANKS so much for your help. You said to get the V26 DM repair kit and provided the link. I found the following 3. Which one do I need and can an average handyman do this repair?
Thanks again so much.
V26 DLP FMT PWB repair Kit
V26 Chassis Block Capacitor Kit
V26 DLP Signal PCB Repair Kit
  • Mitsubishi Master
  • 8,617 Answers
You need the V26 DM kit, they should have it listed as well. Yes if you proceed slow and mark the wires its a fairly easy repair. The hardest part is disassembly of the chassis block , but go slow and you should have no problem.
Posted on Sep 26, 2008
The timer light is continuosly blinking when i plugging in the tv (mitshubishi wd-5252) and won't reset?
Thats one of the famous capacitor issue most likely. Thats the V26 Chassis DLP and usually that symptom is caused by failed DM and Power Board capacitors. There is a repair kit that will work in alot of cases with that symptom. Its called The V26 Chassis DM / Power repair kit available at the following link with detailed instructions http://tvrepairworld.com/mitsubishi_repair_kits
Apr 03, 2013 | Mitsubishi WD-52525 52" Rear Projection...
Timer light is flashing and i reset but still can't get it to come on. timer Light still flashing can you tell me what else I could try? TV has been off for about a month.
You can get the V26 Chassis DLP DM repair kit at the following link which usually repairs that issue. www.tvrepairworld.com the kit contains the capacitors and detailed instructions on CD.
Sep 05, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Timer light is flashing and my tv wont turn on. i have unplugged and still just flashing light
Thats the dm board failing to boot up. replace the capacitors. You can get the V26 DLP DM repair kit at the following link the kit contains the replacement capacitors and the cd with detailed instructions
http://www.tvrepairworld.com/
Jul 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Stanby timer light blinking
you need the V26 DM kit which will usually cure that issue. Its chaep and contains the Replacement capacitors and step by step instructions. Heres a link to the correct kit.
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-dm-pwb-repair-kit/cName/repair-kits
Jun 20, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Timer light blinking green
you need the repair kit for the DM you can get the kit at the following link whic contains the capacitors and step by step instructions on how to do the repair
May 23, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Greem led timer light is flashing and the tv wont turn on what do i do ?
you need to replace the capacitors on the DM power board. You can get The V26 DLP DM repair kit at the following link which has the caps and full instructions with pictures.
Apr 08, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
577 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
