Question about TMI Products VizuaLogic 703-99000-6005 Chevy / GMC Pick-Up / Avalanche / Suburban / Tahoe 99/00 - 02 Med. Neutral... Car Video Player
Headrest installation how do I remove back of seat to do wiring for my headrest
Do not remove the entire seat, just fish the wire down to the bottom.
Posted on Jan 08, 2009
Do you have printable installation instructions for the Roadview RHM 7.0 headrest? We seem to have misplaced ours. Thank you
Headrests slots are different in many vehicles. You can take the slots out of your other car & install them into the SUV bit it is a pain to do. Most are sewed in. Take small edged knife with thin blade, cut down the side of the slot,close to metal so to cut the stiches holding it in place. Some use Glue. Then take out other slots from headrest in SUV, same way. If glued,thats good,just glue your set to use back in. If stiched,just buy Auto Uphostery Glue & use that. Will work. Good Luck,not easy task.
May 17, 2014 | Roadview RHM-7.0 Universal Replacement...
Installed dual DVD headrests, they both get power to them because the buttons light up...one screen flashes white then turns black, the other screen stays white. None of the buttons do anything, not e
Sorry I can't help you but maybe you can help me. I also ordered a set of these Anbotek DVD headrest players on ebay a few months back and trying to figure out how to install them in the minivan. Did you get any instructions? If so how did you get power to them so they work? Any help would be appreciated. thanks
Jan 19, 2014 | TMI Products Vizualogic Headrest Pair...
The headrest video screens in my 2005 Chevy Suburban have suddenly lost power and will not turn back on. Why and what can i do?
cheak ur dvd player or your screen and make sure that u have a good and strong ground and make sure no wires are loss and if that dont work then cheak the monitors wires and make sure they not loss
Apr 13, 2010 | TMI Products Vizualogic Headrest Pair...
Forj model number dvd72hr. just wanted a little more info than what the directions give before i start this project.
dvd72HR dvd headrest for cars. They haven't any information on installation of these headrest. How do you get to the wires once you put the headrest on?
Mar 13, 2010 | Car Audio & Video
Iv hade these forj dvd monitors installed but i can only get sound on the radio
The monitor only headrest does not have audio handling circuitry in it. the wire harness for that side is the one with the red and black wire, and the two video inputs, not the harness with the red and black wire and the three RCA jacks. It will function on the wrong harness, but it is not the correct one.
The DVD headrest has two harnesses. One of them is for power and output, the other is for input only from another source. The harness with the red and black wire has the three RCA outputs... the video lead goes to the other headrest, and the audio can be fed to an aux input on a stereo or amplifier. The input harness is designed to be Video 2 input from either a gaming system (a Game Cube is a nice option), or another DVD or video source (hand held video device such as iPod or Smart Phone like a HTC Touch Pro 2).
As for why you have NO sound, press the FMTX button repeatedly till the screen displays no FM transmitting frequency. Then you should be able to turn up the volume on the DVD player headrest only.
Nov 17, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
Walmart dual headrest dvd player has no sound on passenger side
Oct 09, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
I have just bought a car with an overhead tv i dont know how to get power to it
    Headrest TV
  1. Step 1 Disconnect the headrest from the car seat and remove its upholstery. Trace the outline of the TV's mounting frame onto the foam cushioning with a permanent marker.
  2. Step 2 Cut a hole into the foam using a razor knife for the frame to fit into. Using the frame as a guide, whittle into the hole until it is deep enough for the frame to fit into. Glue the frame into the hole with contact cement and poke another hole into the foam with a screwdriver where the frame's cable hole is.
  3. Step 3 Place the headrest's upholstery cover back on and cut the fabric away where it is over the frame.
  4. Step 4 Place the TV into the frame once the contact cement is dry and hard and run its cable through the other hole. Connect the TV to its tuner console with audio/video cables and store the tuner under the seat.
  5. Step 5 Connect the TV's power adapter cable and route it so it can plug into a cigarette lighter adapter. If it doesn't use one of these, it will have a three-way cable where one connects to the car starter, another to a constant 12-volt source and the last one to a good ground. Disconnect the negative battery cable before connecting any wires
  6. Overhead TV
  7. Step 1 Make sure there is a metal sheet installed in the ceiling below the headboard. This is needed to mount the overhead player onto.
  8. Step 2 Pull away the upholstery on the ceiling. This might require a solvent that will remove the upholstery's adhesive. Insert a plywood or metal sheet between the headboard and upholstery and glue it to the upholstery.
  9. Step 3 Mount the TV set to the ceiling, making sure the screws for the TV's mount are securely screwed into the sheet within the ceiling.
  10. Step 4 Route the wires to the engine compartment if the TV doesn't use an adapter plug for the cigarette lighter. With the negative battery cable unplugged, connect the TV's red wire to the starter's electrical connector, the yellow to the battery or other 12-volt source and the black to a metal ground like on the chassis.
  11. Dash TV
  12. Step 1 Unplug both battery cables from the car's battery, starting with the negative terminal.
  13. Step 2 Remove the stereo from the car. Pry away and remove any trim panels on the dash, then unscrew the mounting screws on the stereo and disconnect the electrical connectors. Some stereo units have an anti-theft mounting system requiring special tools that fit into holes on the stereo front to release its mounting clips.
  14. Step 3 Place the TV within an installation kit designed for your model carmag-glass_10x10.gif. Connect the antenna's cable to the TV and mount the antenna on the outside of the car; the trunk or the roof near the door frame are two possible locations. Route the cable along the weatherstripping or secure it to the side with cable ties.
  15. Step 4 Connect the TV to its tuner box with RCA video (composite) cables and store the tuner somewhere secure, like the glove box. Wire the TV to the radio antenna and stereo connectors with a wiring harness designed for your car, which can be purchased at a car audio supply store.
  16. Step 5 Mount the TV into the stereo's old spot within the dash, fasten all the mounting screws and replace the trim panels. Reconnect the battery cables once the set is mounted, starting with the positive terminal.
i hope this will help.you can send a message if you not satisfied
Sep 10, 2009 | Necvox Car Audio & Video
Dvd screens in headrests are not getting power
The problem seems to be that the video out from the kenwood head unit is either faulty or the leads from the head unit to the monitors are faulty. Have you checked to see that the head unit when playing a DVD is set on ZONE 2 so that it transfers the video signal to the headrest monitors?
Jul 12, 2009 | Kenwood DDX-6019 Car DVD Player
Can't feed the wires through the seat
make a **** at the bottom corner of both seats -place the **** near the center of the vehicle on both seats feed a clothes hanger through the top and wiggle that thing to the **** at the bottom-connect your wire bundle to the hanger with some good ole duct tape and pull it on through-gently-when the wire bundles emerge at the bottom - see about tucking them under the center console and keeping them hidden all the way to where you need to connect them-hope that helps
May 14, 2009 | XO Vision XO-1400 Car DVD Player
HEADREST dvd player honda odyssey 04 exl
Do the headrests detach?? If they do, you can buy the pair of 7" headrest DVD/Monitors all-in-one from Farenheight (made by Jensen). I have used these several times. Not only do the headrests match,but the product lasts too! The best part is that they are about 1/2 the price of many others.
Larry T
Winona Lake, IN
Jan 28, 2009 | TMI Products Vizualogic Headrest Pair...
Car Audio & Video Logo
397 people viewed this question
Top TMI Products Car Audio & Video Experts
xxxxxx xxx
Are you a TMI Products Car Audio and Video Expert? Answer questions, earn points and help others
