Question about Alpine Car Audio & Video
I need to connect an Alpine Stereo to a 12v battery in a boat. I know that that is not recommended but we got it used. I am not sure which wires to connect to where. Could you please help me?
  • 1,586 Answers
Connect the yellow wire directly to the battery (this is constant 12v power, to maintain memory settings). Red wire gets wired to the switched 12v system (so that the stereo turns on and off with the ignition). Blue wire (or blue/white) would be for an antenna or an amplifier (if not used, just seal it off with electrical tape). Orange wire isn't used (that's a dimmer wire for tapping into a car's dash light dimming). Black is ground. The rest of the colored pairs (gray, gray/black, green, green/black, white, white/black, purple, purple/black) are the speaker outputs. The wires with the black stripes are the negative wires in each pair. They usually say on them which color corresponds to which speaker location (front left, rear right, etc). If not, take a look on the Alpine unit - sometimes there's a decal or diagram on there, or a list, which will tell you which wires to connect to which speakers.
Posted on Sep 27, 2008
I need help hooking up a rca converter box in a Lincoln town car carter with the alpine stereo system
Is the converter powered or passive? Each RCA (red or white) connection represents a + and - speaker wire for one speaker or channel. So assuming you already have the amplifier you'll cut the speaker wire coming from the head unit. From the head unit speaker wires will attach to the input or hi-level connection on the converter. The other half of the wiring goes to the speakers in the doors. Those will go to the amplifier which is or should be fed by the RCA's on the hi-level converter box.
Passive coverters don't require 12v power but active ones will need 12v input from a remote signal such as from ignition circuit or a power antenna to turn the unit off and on so your battery isn't drained with the car off.
Feb 28, 2017 | Alpine Car Audio & Video
Trying to install a Alpine 3552 amp, can't get power, not sure how remote switch works?
make sure you have a good ground. use a continuity tester. local retail or stereo shop sells one for about $10-$20. make sure you have power (fuse should be within 12" of battery). the remote wire off the stereo (usually blue) can be your remote switch. this has to be connected for the amp to work and stereo must be turned on.
Jul 23, 2011 | Alpine Car Audio & Video
I have a 2001 nitro bass boat an i am replaceing my 12v tolling motor w. a 24v. i installed the 2d battery and am ready to connect the wires. There are 2 positive wires, 1 states "battery a"...
Is this a straight 24V system... not a 12v - 24v.Correct..
The best advice is use a 50-60 amp resettable breaker..with 6 gauge wire (minimum 8 gauge) ... make sure your connections are clean, tight, and greased to prevent corrosion. USE a BIG HEAVY "jumper" cable between the + and - terminals.
Here are several sites that explain what you need to know..
I went from a 12-24v to a straight 36v Motorguide on my 21ft triton.. WOW!!!! talk about BAD A$$!!
I use the felt washers under all battery connections and the battery spray liberally on each connection..
24 and 36 volt Wiring Diagrams
24 volt trolling motor wiring Google Search
https://www.oreillyauto.com/shop/battery-accessories-16452/battery-accessories-16508/battery-cables---accessories-17650/2000/ford/contour?sort=price+asc
https://www.oreillyauto.com/detail/super-start-4986/chemicals---fluids-16461/battery-chemicals-17661/battery-protection/01342/4742198/2000/ford/contour
https://www.oreillyauto.com/detail/bwd-3123/battery-accessories-16452/battery-accessories-16508/battery-cables---accessories-17650/battery-cable/jc312/2601175/2000/ford/contour
Sep 18, 2017 | Nitro Boating
Am wiring my alpine car stereo back to my old car , unfortunately i dont know were to connect the wires , the labels on the wires somehow got cut when i kept it in storage , need help figuring were the red...
First thing you will need to do is to buy a wire adapter for your specific make & year of car. This interfaces the stock wiring plug allowing you to connect the wires from the headunit to the wires of the plug.
Here is a color coding explanation for the wires on your Alpine Deck:
P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
Mar 17, 2011 | Alpine TDA-7563 Cassette Player
I am hooking up the stereo and I know I have power coming to the wires cause the black and yellow ones spark but when I hook them to the stereo I don't get any power
The yellow wire is the constant wire, you need to find the battery + wire which will be red and hooked that to your deck, the red wire is the main 12v wire and the yellow wire is there just to use a little bit of power to keep the memory i yur deck, i.e. the time, cd position stuff like that
May 19, 2010 | Alpine CDA-9825 CD Player
AM FM CD DET FACE CAR STEREO: installed an alpine stereo in my mustang and every...
That's because the memory wire has not been connected to a permanent live supply.
There will be an ignition switched 12v supply and a memory wire. The first is yellow on many brands and the second is red, but you need to refer to your fitting manual to check or look directly at the wiring harness as the wires are often individually labelled.
Since they both take 12v some folks mistakenly think that they can just be piggy-backed to each other and feed from the same supply. They can, but only if it's to a permanent live feed but that then leaves the risk of the unit being left switched on when the car is parked and draining the battery.
May 07, 2010 | JVC AM FM CD DET FACE CAR STEREO
No power to the amp
hi there
its up to you the remote wire is just another power wire.....the remote wire can be by passed but every time you turn off your car you will need to unhook the 12v amp power wire from your cars battery (if you decide to do it this way)..........or you can hook up the blue wire from the back of your CD/DVD unit what ever you are using and every time your stereo turns off your amp will too..........
hope this has helped
Mar 08, 2009 | Alpine MRP-M350 Car Audio Amplifier
Installing CDM-7836 into a Boat
Yes I can help, the blue/white wire isn't meant for that purpose. That wire is meant for an amplifier turn-on. the wire you want to use is the red that is the accessory lead. What I would recommend is finding a constant 12V to hook to the Yellow and hook the switch 12V to the red. This way your radio will retain memory. Or you can connect both the red and yellow to that switch and never turn the switch off. Simply use the on/off button on the radio. Good Luck I hope I could help.
-Andrew Hawkins
Jun 18, 2008 | Alpine CDM-7834
Car stereo
Sounds like the remote wire on the stereo is either disconnected or connected to the battery +12V instead of the switched 12V (which is switched on/off by the ignition key). If the stereo turned off before and just recently it doesn't turn off with the key, I'd vote for a broken/disconnected wire.
Mar 27, 2008 | Alpine CDA-9855 CD Player
Wiring an alpine cdm9807 rb to a citreon berlingo van
The 'illumination' wire is to hook up to your headlight switch to back-light all buttons when headlights are on. The pink and black audio interrupt I believe is for hands free cellphone communications it will cut out audio when you have a call and have your hands free hooked up through your stereo. The remote turn on is for external amplifiers it provides a small amount of power to to turn on/off external amplifiers. As far as your unit not working I would make sure you have a sufficient ground using a voltmeter and make sure your battery lead is fused and fuse is not blown. You should have a memory lead(maybe yellow) that need constant 12v and a ACC power that needs switched power that is only on with key(usually red). Hope this helps! :)
Feb 25, 2008 | Car Audio & Video
Car Audio & Video Logo
103 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
