I had to replace the heating element in my dryer. It was not sutting off and not heating. The heating element had a burn mark on the connection. After putting on a new element, I plugged in the power turned on the timer switch and push the start button. I started hearing some clicking noise from the top of the dryer where the timer switch is. Now i get nothing. Is the timer switch my problem?
1. No power to the dryer Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Check the following to address this issue.(Most common issue will be a burned out thermal fuse.)
Heating element
Thermal fuse
1. A burned out heating element will show no continuity when measured
2. Most dryers have a thermal fuse, which burns out when the dryer
If all checks out OK above, replace the main control board.
Heating element
Thermal fuse
Check the following to address this non heating issue
or replaced.
2. Heating element
3. Thermal fuse
