Question about Epson Stylus RX500 All-In-One InkJet Printer
Scanner not working
Copy does not work, sometime I get a scanner error and other times it just prints a very faint image of the paper I'm trying to copy.
I took the scanner cover off the printer and found the ribbon cable is twisted and strained. Looks like the electrical connection is bad.
Does anyone know how to get replacement parts for this or a reasonable repair site? I think it will cost me more to fix than buy a new one.
    Problem Solver:
  • 14 Answers
Yes, its true. It will cost more to repair the printer than have it replaced. But If you need a servicer, reply with your zip code ill see if i can search one for you. For the parts of the printer, go to compass-micro.net.
Posted on Oct 29, 2008
There is a faint line when i make a copy
you culd try to clean the scanner glass. open the top document feeder and make sure that the big platen glass as well as the small scanner glass is comletely clean.
If the fiant lines apear if you print as well the problem is most likely with the imaging process and the unit will have to be taken to a service centre to be looked at.
hope it helps.
May 22, 2012 | Office Equipment & Supplies
How do you scan an image onto the computer using the Canon MP190 series? Ive tried hitting scan and it only tried to copy the image and print onto paper.
Place the paper you wish to scan on top of scanner.
1. Go to window start manu.
2. Find picture board.
3. Click the file manu at picture board, and find the scanner.
4. Click the scanner and it will scan the paper as soon as you click ok...
5. After completion of scan, click "save as" and name the title wish to make.
That's all...
Apr 21, 2011 | Canon PIXMA MP190 All-In-One InkJet...
Scanjet G4050 - Image is sometimes at an angle in PDF scan, even though paper and original text was straight. How to prevent this?
Hello
This is a flatbed scanner. Since the paper is aligned to the sides of the scanner the problem could be two things:
- The paper guides on the sides of the scanner are not accurate to the scanning path
- The scanning bar is not moving parallel to the sides of the scanner (one side is slightly ahead of the other side).
I had a similar flatbed scanner and the paper guide was off about 1/16" - so all scans were either tilted or I had to manually move the paper on the glass to correct.
HP do have directions on how to maintain your scanner - http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&taskId=125&prodTypeId=15179&prodSeriesId=3236371
- but it does not include any info on how to re-calibrate it. So it would appear that this is something you will have to manually correct.
Download and print out something with a grid or ruler measurement on it. This site has some examples - http://www.imaging-resource.com/PRODS/HPPSS/PSRESV.HTM
Align the page normally and scan it with your scanner, print the results. Compare the scanned print to the normal page and adjust the paper accordingly on the scanner.
Once you have the new location for originals on your scanner, take some construction paper or poster board and trim out pieces to tape or glue to the glass of the scanner to form a new paper guide.
While a calibration tool would be better, this method will definitely work.
Dec 03, 2009 | HP Office Equipment & Supplies
Esp3 printer, has new cartriges, printing very fient
Have you tried the maintenance tool - if you open the kodak printer status monitor in your taskbar (next to the clock); at the top right hand side you will see an icon showing crossed hammer and spanner, click on this and run the tools from top down (dont need to do the test page).
If that doesnt work you could try this:-
my new esp3 printer (replaced due to not printing black) came with a suppliment document for action if no black or faint print appears!!:
verify paper is loaded into paper tray then press and hold the Cancel and Copy/Resume buttons simultaneously until the On/Off light flashes -apparently this fixes the no black/faint issue.
hope this helps
Jun 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Scanner and copier do not work
In your case, the scanner light is not lit during the scan or copy. If you print something from the pc, it would print just fine. Try to powercycle the printer, then try copying again. If it persist, scanner is defective but you may still use it to print from pc.
Mar 05, 2009 | HP PSC 2355 All-In-One InkJet Printer
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
COPY PROBLEM
You have a scanner problem.  You might try and make sure you're using the right plug for it.  If you can figure out how to take the glass off, you should try cleaning all the glass and mirrors.  You should also clean the area just above where the scanner rests when it's not being used (you'll see a white strip there).  If none of this works, you'll probably need a new scanner.  Junk the thing.
Oct 26, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
WILL NOT COPY
Dear, after changing the cartridge, printer print a test print. OKAY. Take that test print and put it on the scanner (printed area should on the side of mirror) then press "scan" button on your printer "bottom left". When the light stop fluctuating. Keep out the paper from the scanner. After this Printer will work properly
Sep 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
Epson Stylus RX500 All-In-One InkJet Printer Logo
44 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
