Question about Hotpoint 24 in. DWF34 Built-in Dishwasher
Hotpoint dwf34 dishwasher
Hi, I have a problem with a dishwasher that has been sat in the garage for 5 months and I have plumbed it in today. When I switch it on, water comes in the bottom but does not heat up, it immediately starts to pump water out (cold) in little spurts, a second or so at a time and it continues to do this. The time remaining on the wash cycle does not decrease and it just stays in this loop. I have checked the impeller and that is not blocked. I would appreciate any help you can give me.
Thanks.
First I'm no expert. Second I have a DWF34. Try taking the left hand side cover off by removing the top (held on with 2 clips at the back) and then undoing the 2 torx screws visible on the left hand side when you open the door. On my appliance there is a red plastic bar attached vertically, located near the bottom just to the right hand side of centre which attaches the flood float to a micro switch. Check that the red bar moves freely and that the micro switch clicks on and off. If you have an electrical tester check that the micro switch works.
Beware close contact to electricity can often be detrimental to health ... unplug the appliance before you touch anything.
Posted on Nov 01, 2008
Machine has power and appears to be running but no water is coming through
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Dec 30, 2010 | Hotpoint 24 in. DWF34 Built-in Dishwasher
Board has blackened deposits on back directly under what looks like a relay of some sort . does this mean the board needs replacing
Hello & Welcome to FixYa
You are right when the relay is burned replacing the board completely is recommended repair, hope you understand there is no other way to solve this problem. Please get back to me if you have any other questions.
Kevin
Dec 12, 2010 | Hotpoint 24 in. DWF34 Built-in Dishwasher
Our DWF34 is leaving residue on some items (usually the ones which have had mag or oil on. Plus glasses, plastics are not dry at end. I have interrupted the wash a few times and found that there seems to...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 03, 2010 | Hotpoint 24 in. DWF34 Built-in Dishwasher
Hotpoint dishwasher bci450
Here are the eco related error codes for your washer..
1)Light 3 (eco) flashes. Water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
2) Wash indicator lights 3 + 5 (eco + pre) flashing rapidly. Filter is clogged. Pull out the filter and clean it.
3)Runs for approx. 3 minutes and then stops. Lights 3 + 4 (eco and fast) flash. Probably caused by being plumbed into a hot rather than cold water supply. The incoming water is hotter than required for the wash which causes the machine to cut out. Plumbing the machine into a cold water supply will fix the problem with no apparent long term problems.
May 23, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Hotpoint aquarius dwf30 dishwasher
you can plumb into hot but there are some snags
first hot water pressure is often a lot lower than cold so the machine may take a long time to fill
second if the water is too hot it will destroy the resin of the water softener and you will see brown marks on the crockery.
third it a bit uneconomical as you will use a lot of hot water
May 18, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Flashing Lights
this error code is time out draining, check for a blockage
Jun 05, 2007 | Hotpoint 24 in. DWF34 Built-in Dishwasher
Dwf34
is it heating up properly? if so the pcb may be faulty.
Jun 04, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. DWF34 Built-in Dishwasher Logo
395 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
