If the tablet has a micro sd expansion slot you might be able to run the games from there but you might have more success using a usb adaptor for the card and a lead with a usb socket at one end and a micro usb plug at the other plugged into the tablet.
The tablet should recognise the usb connection and invite you to download or run files just as a pc would.
the applicatioin have to have the ability to be moved to an SD card example: the app "fruit ninja" scroll or look near the bottom of the application page or whatever you call it it should say somthing along the lines of "modify to SD" or somthing then the app has the ablitiy to be transfer over an SD card and so on. if the app page does not say "modify to SD" chances are your not able to tranfer it over SD card unless you use your usb mini cord or whatever cord you used.
I find charging for 24 hours before use will yield the maxium capacity, after that overnight charge is fine. I would wait until tablet is activated before the sd cards are inserted.
put micro sd card into usb with a usb micro sd holder a put music or photos onto it/put micro sd back into viewpad slot next to sim card slot /thats it.
You can connect you Archos to you computer by the USB cable which have came along with the tablet.
From tablet you need to choose mass storage device when you connect the cable.
Once Mass storage activated you will see your tablet or SD card on your computer.
You can copy paste or drag and drop songs from your computer folder to archos tablet Music or Media folder.
Or
You can use various Sync application from Android Market. Below given link is to list of applications available on Market. Please read description before you purchase or install any application.
https://market.android.com/search?q=itune&so=1&c=apps
First, you must be on android 2.2 or higher to do this. You can download the update here: http://www.archos.com/support/support_tech/updates.html?country=us&lang=en
Next, once you have the new firmware, you go to the applications menu in settings. Once there, select a program you would like to move to the sd card and in that menu press the move to sd card button.
Just use the provided USB cable and connect the tablet to PC. Windows will recognize it as another drive (USB Mass Storage similar as USB HDDs and USB sticks). Copy the APK file anywhere (for example to Downloads folder. Then unplug from PC and run the Files application on Archos. Browse to the directory and clicking on the APK filewill start installation process.
