Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Flashing timer light, cannot turn on tv
Thanks for your previous response. (Are you asking about the wd62525? If so that's a v26 chassis and equipped with a self diagnostic test by flashing a series of two digit sequence after depressing the power button. After depressing the power button count the number of flashes - then you'll see a slight pause - then another series of flashes. (for example: four flashes, pause and four more flashes is an error code 44). The unit repeats this coding at least three times so be as accurate as possible.)
I cannot turn the tv on at all? The flashing timer light is consistent with no pattern.
Thanks again...
  • 4 more comments
  • 5and10 Sep 28, 2008
    34 Lamp Abnormality we just replaced the lamp the end of April and are getting this error code is this TV worth the trouble or should we just get another one and save us the money.
  • booones2 Sep 28, 2008
    Tried to hold the menu and device buttons for 6 seconds and still the timer blinks constantly.
  • jfarr244 Oct 03, 2008
    Same problem. No codes after power button or “device” “menu” button depressed for six seconds. Problem history: Problem started with timer blinking after shut down. If I depressed the re-set button, after 1 minute the blinking stopped allowing for a startup. While viewing the picture it would become vertical stripes and then after 1 minute the set turned itself off. The timing light would then stay on, requiring the reset button to be depressed, on infinity. The local technician listening to this description over the phone wants to replace the chassis. Ideas?
  • tclark9080 Oct 15, 2008
    The timer light keeps flashing. Im have sound but no picture. I pressed the re-set button. The light goes out when it's pressed and then goes right back on. I have un-plugged TV and light comes right back on when it's plugged back in.
  • Anonymous Nov 05, 2008
    Green Timer Light stays flashing. Can reset TV, but stays on only for 2 minutes. Will not tun back on until reset. Local TV techs said it is the caps and that they have attempted to fix and also sent chassi to Mitsubishi. The end result was that it is not fixable and what Mitsubishi tried to fix, didn't work. End result, the TV is not fixable. What is one to do. Can we complain to the company and get some restitutions.
    Thanks, Dan Dan's Photography dansphoto@gotsky.com
  • Anonymous Nov 11, 2008
    I have the same problem and I can not find any help from Mitsubishi. I do not know if I should buy a new TV after what I found out in the internet...
  • 934 Answers
Press and hold "Device" and "Menu" buttons for six seconds and see if you then get a patter of flashes pertaining to the error codes... I would suspect one of the following codes:
12 No Error Detected
22 Recovery From Momentary Reset
32 Lamp Cover Open
33 Air Filter Cover Open
34 Lamp Abnormality
35 Chassis Fan Failure
36 Exhaust (Back Cover) Or Lamp Ballast Fan Failure
37 Engine (Dmd Or Lamp) Fan Failure
38 Excess Lamp Temperature
39 Excess Dmd Temperature
41 Short Detected
44 Dvi Cable (Between Chassis And Engine) Disconnected
Bill
Posted on Sep 27, 2008
  • 41 Answers
If the timer light keeps flashing with no pattern. You have one or or two problems first the CAPs on your power supply board are puffed and need replaced. There are usually four of them that go out on the power board they are in the top right hand side of the power board. IF this does not fix it then you have a bad FMT board and it is no longer available.
Posted on Oct 06, 2008
  • 179 Answers
If you want to have it repaired email me at ima_rm2000@yahoo.com i have repaired over 200 of these sets. I have been a professional electronics technician for over 40 years. email me for details and pricing. beter prices then mits or pts
thank you
Posted on Nov 05, 2008
The timer light is continuosly blinking when i plugging in the tv (mitshubishi wd-5252) and won't reset?
Thats one of the famous capacitor issue most likely. Thats the V26 Chassis DLP and usually that symptom is caused by failed DM and Power Board capacitors. There is a repair kit that will work in alot of cases with that symptom. Its called The V26 Chassis DM / Power repair kit available at the following link with detailed instructions http://tvrepairworld.com/mitsubishi_repair_kits
Apr 03, 2013 | Mitsubishi WD-52525 52" Rear Projection...
The timer button is flashing and we can not use the TV I cant find my booklet on the TV
Install the Mitsubishi repair kit called the V26 Chassis DLP DM / Power repair kit form www.tvrepairworld.com the kit contains the capacitors and the CD with instructions. That kit will usually repair the blinking timer light symptom.
Oct 20, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Timer light will not stop flashing. can't turn on TV
Unfortunately the first generation DLP's from Mitsubishi are prone to have Capacitor failure through out the chassis. Most likely that is what your set is experiencing. I would start by replaceing the suspect caps on the DM amd The Power boards. You can get the V26 Chassis DM/Power repair kit from www.tvrepairworld.com which also contains instructions.
Jun 21, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Thats the V26 chassis which is famous for having failed capacitors on the DM and Power boards. You can get the V26 DM/Power repair kit from www.tvrepairworld.com the kits contain the cd with instructions.
Apr 06, 2010 | Mitsubishi WD-62525 62" Rear Projection...
The timer light on my tv keeps flashing and we are unable to turn tv on...help!
The V26 Chassis DM repair kit from www.tvrepairworld.com will usually repair that issue. The kit contains the replacment capacitors and the CD with detailed repair instructions
Nov 14, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Timer light is flashing and i reset but still can't get it to come on. timer Light still flashing can you tell me what else I could try? TV has been off for about a month.
You can get the V26 Chassis DLP DM repair kit at the following link which usually repairs that issue. www.tvrepairworld.com the kit contains the capacitors and detailed instructions on CD.
Sep 05, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have a mitsubishi tv model # WD 52525 DLP and the timer light just keeps flashing and the TV will not go on
i have a mitsubishi ws-55859 rear projection tv. the green timer light just keeps flashing and the tv will not turn on.
Aug 09, 2009 | Televison & Video
Red light stays on after lamp replacement and reset
if the lamp light still remains solid red its most likely needing the capacitors on the power pwb replaced very common problem with the V26 Chassis DLP. You can get the V26 power pwb repair kit at the following link which contains the replacement capacitors and step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Feb 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Repair for flashing timer light.
you need the V26 DM kit, they should have it listed as well. Yes if you proceed slow and mark the wires its a fairly easy repair. The hardest part is disassembly of the chassis block , but go slow and you should have no problem.
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Timer light will not go off and I cannot turn on TV
ybhughes,
Are you asking about the wd62525? If so that's a v26 chassis and equipped with a self diagnostic test by flashing a series of two digit sequence after depressing the power button. After depressing the power button count the number of flashes - then you'll see a slight pause - then another series of flashes. (for example: four flashes, pause and four more flashes is an error code 44). The unit repeats this coding at least three times so be as accurate as possible...
Bill
Sep 26, 2008 | Televison & Video
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
3,046 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
