Question about Dryers
Kenmore ddryer 11072812101
The dryer go throught cycle but no heat. if it is the pilot light why would it go off and where is it located of the machine
  • 5,911 Answers
Your dryer does not have a pilot. The dryer has an igniter on the burner assembly. When you push the start button, the igniter begins to glow. Once it reaches a certain current potential, the gas valve is opened, gas flows and you have ignition. This is a a built in safety feature of the burner assembly that prevents free flow of gas without ignition. Without it, you could have a build up of gas inside the dryer cabinet followed by the loud "phoooom!' of an explosion when it finally DOES ignite. More commonly the igniter either fails to where it does not glow, or becomes weak and will not produce the required current to open the gas valve. The following link explains a little theory about glow bar type igniters and what their current potential should be:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
I know the link is for a gas range, but the igniters in some of these appliances are identical and the theory is the same.
Another cause of an ignition failure are bad gas valve coils. There are two of them on your burner assembly. It is recommended that if one fails, you replace BOTH of them at the same time. If you go to searspartsdirect.com and type in the model number you provided, there's an excellent exploded view diagram of your burner assembly and parts. The igniter is listed as item number 4 (part #279311) and the safety valve coils are items number 13 (part #694540) and item 14 (694539).
If you can view inside your dryer under the drum, you should see an orange glow as the igniter comes on. If you do not see the glow, or if the igniter glows and there's no ignition after 90 seconds, I would recommend replacing the igniter. If the dryer ignites, then shuts off after a short period of time and will not reignite, you may have a bad coil (you may hear a rattling sound too).
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 27, 2008
Stops and all the lights come on
Instructions
    • 1 Make sure the home's gas supply valve is turned on. Check your Maytag owner's manual to find the location of the dryer's gas shut-off valve. This is usually behind the dryer's front panel or in the back of the unit. Open the valve to allow gas to flow into the dryer.
    • 2 Open the lower front panel of the dryer to access the pilot light assembly. Press and hold the starter button as you light the pilot with a handheld lighter. If you have trouble getting it to light, release the starter button and wait a few minutes before trying it again. Once the pilot is lit, hold the starter button down for another minute to make sure it will stay burning.
    • 3 Close the dryer's front panel and run a test cycle to see if it is producing heat. Call a repairman to evaluate the problem if lighting the pilot did not restore the heat.
Jan 15, 2013 | Kenmore Dryers
My dryer has no heat. is the pilot light out if so where would it be located?
Gas dryers have an electric igniter, no pilot light. If it runs but doesn't heat, it could be: igniter or thermal fuse
Mar 24, 2011 | Kenmore Dryers
I have an old Kenmore 70 Series dryer, just this weekend, the drum turns but no heat..... after a little search online, I suspect the pilot light went out. Where is the pilot light located? I lost the...
The burner is on the lower right side of the bottom under the drum. See this manual pdf page 23 for location and access. https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
The burner uses an ignitor and a flame sensor vs a pilot light. See this link pages 12 - 14
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/c5c81d2c8f26b1b5852574f20055c20c/$FILE/4314010.pdf Note the M series burner has been in use since 1984.
The dryer must have a complete termperature circuit and no "high temp limit" failures for the ignitor to light. That means the door is closed, motor is running, and the cycle thermostat is less than 135 deg F and the High limit thermostat is less than 180 deg F just to provide power to the gas valve solenoids, ignitor, and radiant / flame sensor.
Thanks for choosing FixYa,
Kelly
Nov 28, 2010 | Dryers
My Kenmore 90 series dryer's pilot light is out. What can I do? I have a Kenmore 90 series gas dryer and its not getting heat.  If I look at the igniter which is a carborundum igniter and I don't see...
Hi, You should first check the fuse. If the back comes off try this:
UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it. If the rear panel does not come off, please get me model # and I can assist you further.
Please let me know if this helps you.
Thanks
Vic
May 28, 2009 | Dryers
Dryer will not heat
The answer is no, you do not have a pilot light. What you have is an electronic ignition which is faulty. Call in a repairman and you will be back up and running in no time.
May 17, 2009 | Kenmore 74992 Gas Dryer
Heating on series 70 Kenmore Gas Dryer
suspect the 2 black coils on gas valve/burner after first heat cycle they will open and not work until cool down
Nov 26, 2008 | Kenmore 70172 Gas Commercial Dryer
Cycles but no heat
The igniter needs to be near the burner jet in order to get a flame started when gas is provided,, the thermo fuse should be situated on the heat duct. I do not have access to Kenmore service manuals to provide any specific darwing details.. my comments are based on other brands.. I hope this helps..
Aug 30, 2008 | Kenmore Dryers
Kenmore Elite gas ddryer model 72062--No heat
Check the glow coil ,if its not glowing run a test for voltage when its heating ,should be around 117 volts.check thermal fuse.
Please Rate This !!!!
Aug 10, 2008 | Dryers
Kemore Elite Dryer - no hot air
kenmore gas dryer heats at first, then cools off rest of cycle.
Jul 26, 2008 | Kenmore 74602 Gas Dryer
Pilot light
Pilot Light? Are you sure? All the gas dryers I've ever worked on were pilot-less. There should be a glow-type ignitor that heats up when the dryer is turned on. When it reaches a certain current potential a gas valve is opened and the burner ignites. How old is this dryer? Maybe this is something I've never seen before.
Jun 05, 2007 | Kenmore 72802 Gas Dryer
Dryers Logo
236 people viewed this question
Top Dryers Experts
