Question about Wave Industries OLY-OL3000 Globe Phone
Blank line through display
There is a line running through the display on my unit. Can this be fixed?
    Problem Solver:
  • 8 Answers
Yes. The problem is broken connections where the LED board is soldered to the rotor board. Feel free to e-mail me for more help derby503@cox.net
If you can solder with a fine solder gun you can fix the problem!
Posted on Oct 01, 2008
I have a xt500c thermostat the display goes blank stay off a few days the thermostat comes back on and the unit will run than it will go off again
Sounds like you have a clogged drain. Drain is draining enough to clear the float switch, unit comes on produces water, water backs up and trips the float switch again therefore killing power to the tstat. Shop vac the drain line!
Jun 30, 2017 | Heating & Cooling
Why won't my U-line refrigerator turn on at all?
What is the model number of your unit?
Nov 11, 2012 | U-Line Refrigerators
KitchenAid KCMS1555RSS - display completely blank and does not function. Is it worth fixing?
i would try and see if the fuse is blown in unit ... normally behind control panel there is a in line 20 amp fuse that may have blown.... if the unit makes noises when you touch the buttons but no display then you have a bad control board assembly
Jan 11, 2011 | KitchenAid KCMS1555RSS Stainless Steel...
Display gets blank when running
If you install this unit then I suggest that you unplug unit then remove motor shroud and inspect the lower board connection then, remove the upper console check all connections. If you are able or someone else can plug in unit then start it without walking see if the display blanks out in those 4 mins then if it does then tap on the console to see if the display will show the functions.If not call the place that you purchased the unit or call the manufacturer directly you they should send you another display.
May 14, 2010 | Exercise & Fitness
The display turn off after few minutes (blank screen, no message). When it does that, the power led stay green. When I turn it off and on, the display work again for a few minutes and the same problem...
jackperson, Might be internal problem with the units power supply (ac line in to DC conversion) having shutdown issues. You will need to do some reading in my fixya profile for a while and then you will know what to look for inside unit. If not into electronic repair stuff, skip the reading and trade-in unit for new, if current unit is 4, 5, 6 years old. 12fixlouie
Mar 12, 2010 | LG L1730S 17" LCD Monitor
No yardage displayed
The rangefinder is out of alignment. Vibration, dropping these units make small mirrors inside move slightly. Over time the receiver cannot see what the transmitter puts out. Bushnell can fix, 4-5 weeks w/o unit.
Mar 18, 2009 | Bushnell PinSeeker 1500 20-5103...
Blank Screen on Garmin E-Trex Vista
Yes, this problem has been caused by the launch of a new satellite earlier this year. As soon as your unit gets a fix from the new satellite, it causes this problem. Simple immediate fix: disable WAAS in the setup. Permanent fix: go to Garmin website and update your unit's software and it will fix this temporary problem. Enjoy your GPS and don't forget to come back and tell us if this fixed your problem.
Aug 19, 2008 | Garmin 010-00358-00 GPS Receiver
'03 BMW 530I Radio
I think replacement of the face unit is needed. the LED's that illuminate my have been pixelated through sun exposure. Replacement necessary.
Feb 13, 2008 | Car Audio & Video
Printer screen
Your display is blank because the LCD unit is bad and needs to be replaced.
Jan 10, 2008 | Xerox Phaser 8550DP Printer
Siemens Gigaset 2420 corded unit resets when calls received
OK, here's what happened. I had the same issue of the phone resetting when a call came in, I thought it was a power issue and through some testing it was not. Here's the fix...Menu \ system settings \ enter pin (if you haven't changed it it is 0000) scroll to factory default and reset. This fixed the problem somehow for me, make sure to write down any impotant messages because it will erase everyting (silly me). I hope this helps.
Nov 14, 2007 | Siemens Gigaset 2420 Phone
Wave Industries OLY-OL3000 Globe Phone Logo
252 people viewed this question
Top Wave Industries Lands Phones Experts
Are you a Wave Industries Lands Phone Expert? Answer questions, earn points and help others
