Question about Kenwood Car Audio & Video
I have a problem with connecting my KVT-522DVD to my Ipod and controlloing it. I am using the KCA-IP300V lead and I have upgraded the software to 1.4.0. I am trying to control a Ipod Nano 3rd Generation. Any help would be extremely useful
  • halesp123 Sep 26, 2008
    I have just tried the solution but unfortunately my KVT-522DVD doesn't have a aux enable. The unit has a separate source for the Ipod. I have tried all possible combinations in the menus for this function. Thanks
    Tried the solution please see added comments. thanks
  • Kenwood Master
  • 19,396 Answers
To control the ipod you need to connect the ipod using the proper cable, this one here.
Ensure also that you are following right procedure, follow instructions on manual to control Ipod volume and file selection.
Posted on Sep 26, 2008
    President:
  • 624 Answers
In the set-up or menu of the Kenwood there will be an option to enable an "aux" input. After that is enabled you will be able to select it from using the "src" or source button.
  • Kenwood Master
  • 13,433 Answers
Have you upgraded both devices into the latest available softwares.
iPod nano 3rd generation is only partially supported originally.
I have a 4th Generation iPod 32gb and it won't play sound when o hook it up my kenwood kvt-516
make sure that you have updated the kenwood to the latest software for the ipod--at kenwoods site--What cable are you using to hook up to the kenwood, hope you are not using the usb cable cause that won't work , you have to have a KCA-Ip301V ipod video cable. Here is the firmware link you need-- http://www.kenwood.com/cs/ce/mm/firmware/2010/2010c/eng.html
Dec 27, 2010 | Kenwood DDX516 Car Video Player
I plug my ipod to the stereo but my stereo screen still says discconected
you have to go to the kenwood site and download the firmware update go to this page http://www.kenwood.com/cs/ce/mm/firmware/2008/eng.html
after you download the file unzip it and burn it with either nero or roxio, as a data file insert the cd on your kvt-512, if it reads DISK ERROR, press the reset button on the front of the stereo, once the screen comes back up select the DVD function, the system update should start from there. let it finish once it does then you'll be able to plug in your ipod. oh and ofcourse for this you should know that you need the ipod adapter, depending on what you want to do with it for instance i have the KCA-iP300V which allows me to view videos from my ipod as well.
Jan 27, 2010 | Kenwood KVT-512 Car DVD Player
Kenwood KVT-512 iphone compatibility
Just ignore the airplane mode prompt and if your wiring is correct everything should work.
With my BMW I had to connect both the solid blue (pwr ant) wire and the blue with white stripe (p conn) to the solid blue wire from the factory harness.
It isn't obvious that either of these are needed as the KVT-512 has it's own power supply but the way most factory power amps are installed the power from the KVT-512 is not used and the car manufacturers power amp needs to be turned on.
If you are listening to the radio the pwr ant wire will turn on the power amp, this didn't seem obvious because the BMW doesn't have a power antenna. And when you are using the DVD player or the iPod connection you need the P Conn wire to turn on the car power amp as the ant pwr is disabled because you are no longer using the radio and Kenwood assumes you will not need the antenna so no power to this lead.
Solder all three wires together and you should have sound all the time.
Jul 01, 2009 | Kenwood KVT-512 Car DVD Player
KENWOOD KVT-729DVD & KCA-BT100 BLUETOOTH + KCA-IP300V
Try this. This is the Kenwood support. Hope this helps. :)
By Phone
(310) 639-9000
or toll free 1-800-KENWOOD (536-9663)
Jan 13, 2008 | Kenwood KVT-617DVD Car DVD Player
Just purchased a brand new Kenwood KVT512 and the ip300v interface cable. i can play music from my i pod but i dont have any interface, it basically just acts as an audio input rather then linking to the...
Did you buy the adapter for the ipod and are not just hooking it up directly through usb. It sounds like their may not be the correct adapter attached. The adapter comes with plug for the ipod on one end, and a usb, audio, and video plug on the other end. Without that you will not see anything on the screen due to not having the correct cable to display the video portion.
Feb 24, 2009 | Kenwood KVT-512 Car DVD Player
How do i connect my itouch to kenwood kvt-512???
Hi there! You need a Kenwood KCA-iP300V iPOD VIDEO DIRECT CABLE.
Feb 09, 2009 | Kenwood KVT-512 Car DVD Player
Cannot connect ipod to KVT-522DVD. I am using the KCA-IP300v. I have updated the firmware to 1.4.0. But I still cannot get control of the ipod
Hello. Thanks for everyones help. I went around to a dealer to explain the problem and they spotted that the connection lead was not a genuine one. I had been missold this item as being a genuine item. I bought a geniune lead and everything works fine now.
Thanks once again.
Paul
Sep 26, 2008 | Kenwood Audio Players & Recorders
I NEED ACCESSORY # KCA-iP300V
if you e-mail me at merle840@aol.com i can get it for you -no problem
Apr 03, 2008 | Kenwood Sirius KCA-R70FM
Car Audio & Video Logo
160 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
