Question about Haier Washing Machines
Am I supposed to leave the water on the whole time in the haier portable washer?
  • 32 Answers
Yes,needs to refill during rinse cycles to clean out detergent residue.
Posted on Sep 28, 2008
I have my machine setup through my faucet. In the manual it says to hook it up to the cold water connector. My question is when I am going to wash hot water am I suppose to connect to hot water connector...
I am assuming that it is cold fill only in which case you leave it on the cold supply. The machine will heat the water to the correct temperature for the wash selected ;-0)
John C
Mar 20, 2011 | Avanti 10 lb. Portable Top Load Clothes...
Hi, I bought a Haier 8.8-lb. 1.6 cu. ft. Capacity Portable Top-Load Clothes Washer from two week ago. When water goes into the machine, I found the water came out from drain tube at the same...
Have you got the drain pile positioned higher than the top of the machine. If the outlet of the pipe is lower than the water level, the water will just run out. If this is not the problem then don't even try adjust or open the unit. Take it back to the dealer or you will void your warranty and it is not worth it. Let the dealer worry about it.
Feb 21, 2011 | Haier HLP23E Top Load Washer
My portable haier dryer (HLP140E) has a bad odor. I got it brand new from Walmart. It was happening with the portable washer (Haier HLP21E) too but that has seem to have faded. I've used the dryer a few...
No any smell coming from a dryer is not "normal," no matter what anyone tries to tell you. I would seek a replacement model immediately. You are not the first to complain about this model. Likewise, I would seriously consider a replacement for the washer as well, even though the smell has diminished. I hope this helps and good luck!
Nov 11, 2009 | Haier HLP140E Electric Portable Dryer
Haier Top Load Washer doesn't spin
There can be two possibilities,one if it has a belt, it is either stretched or slipping or if it doesnt have a belt then there is a clutch like device between the motor and the basket, which is either broke or cracked.
Or follow this easy steps...
Unplug the washer and turn off the water faucets.
Disconnect the water hoses and the drain hose and pull the washer away from the wall, leaving yourself enough room to work behind the appliance.
Lay an old towel down to kneel on and soak up any water that leaks from the hoses.
Remove the rear access panel.
Locate the motor. The rubber drive belt goes around a pulley wheel attached to the motor.
Press on the belt. If it gives more than ¾ inch or so, it needs to be tightened.
Loosen the mounting nut for the motor and push the entire motor to increase the tension on the belt.
Hold the motor in place and tighten the mounting nut.
Make sure you don't tighten the belt too much or it will break. You should be able to press on it and feel it give just slightly.
Replace the drive belt if it shows signs of wear.
Thanks for contacting
Oct 13, 2009 | Haier HLP21E Top Load Washer
Popping while removing Hose Adapter
Are you sure the adapters are installed in the correct direction? To release the pressure you could turn the water off, and then turn the washer on. The residual pressure will be released. Then you can turn the washer off and remove the hoses.
May 06, 2009 | Haier HLP21E Top Load Washer
Spin cycles doesn't work, tub full of water
HLP21E Haier Portable washing machine will not spin and drain water
Jul 08, 2008 | Haier HLP21E Top Load Washer
Washing Machines Logo
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
