Question about Garmin GPS
My garmin does not charge anymore in my car there is always an pc image on the screen saying how to charge it but when we need it in the car we cannot charge it in the car when we are driving with it
  • 171 Answers
If your unit will not charge in your vehicle, you may need to replace the fuse located in the tip of the vehicle power adapter.
  1. Unscrew and remove the silver or black, round end piece. my garmin does not charge - e8d79c8.jpg
  2. Remove the fuse (glass and sliver cylinder) and replace with a new fuse.
  3. Ensure that the silver tip is placed in the end piece. Screw on the end piece.
Posted on Sep 26, 2008
Garmin Nuvi 755t Stuck in power up cycle
You can do two things.
First, plug the GPS in overnight in a regular USB charger. If the battery charges up, then the problem is with your Garmin vehicle cable.
If it does not charge up, you can buy a battery replacement kit for it: https://www.amazon.com/Garmin-Nuvi-755-Replacement-Installation/dp/B003VFSR4M
Mar 05, 2017 | Garmin nuvi 755T Car GPS Receiver
I don't have Satellite signal! I tried to acquiere satellite signal with my Garmin Nuvi 1350! The screen always says locating satellites but nothin happens! The satellite bars are not green!What can I do...
Try fully charging the unit and leaving it stationary for about 20-30 minutes if you still dont lock satellites try giving the unit a firmware updates using Garmins WebUpdater software here is a link.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp.
Hope this helps!
Feb 24, 2011 | Garmin nuvi 350 GPS Receiver
I have a Garmin Nuvi 1450 - it will just shut off by itself even when charged and / or plugged in. Please help!
I had the same issue on my 1450 except it just would not power on anymore, even with a full charge. A soft reset will preserve your Home, Favorites, POis, etc. Leave the battery in the unit. Hold down on the lower right of the screen while holding down on the power button. After 20-30 seconds, you should see the Garmin splash screen. Have your PC/laptop ready with USB cable. Get the latest Map update downloaded and installed or just start using the unit again.
Nov 21, 2010 | Garmin nuvi 1450 GPS Receiver
My garmin nuvi 255W does not charge in the car with the car charger. It freezes at the first screen and I can't get past that screen. I found my home charger and plugged it in and now the battery is...
You need a genuine Garmin car charger to both charge and see directions at the same time. If it is a non - Garmin lead you can't charge and use at the same time. the Garmin at the same time. Otherwise the unit just goes into sleep/pc mode. It took a long time to get to the bottom of this, so I thought I'd pass the information on...
Nov 13, 2010 | Garmin nuvi 255W GPS Receiver
How do I charge the Garmin 265 WT with my desktop PC? I don't even know how to tell if the battery needs charging. This is my first GPS and I have no idea how to charge it, tell if it's on, etc etc
yes, you can use your pc via the usb cable provided with your unit, or the car charger.
to tell if its charging, go to the map screen then menu, the charge indicator is on the top right of screen...should be green while charging.
bill
Oct 19, 2009 | Garmin n?vi 265WT Car GPS Receiver
Charging my nuvi 250 with a USB cable from my apple
When the GPS is hooked up to charge the battery it will say charging,try turning it on when hooked up and see if it is in fact charging,otherwise have you thought of purchasing a wall charger,I got mine on Ebay,very reasonable and works great,saves the hassle of hooking up to my comuter.Hope this helps with the problem.
Sep 29, 2009 | Garmin nuvi 255W GPS Receiver
ZUMO CHARGING STATUS
I have had Zumo 550 for 2 years now, and it does exactly the same.
I think it is just the way the unit is, and is not a fault.
Feb 14, 2009 | Garmin zumo 550 GPS Receiver
NEW PURCHASE AND PLUGGED INTO AUTO TURNED ON AND GARMIN LOGO APPEARED AND THEN SCREEN WENT BLACK. DOES NOT WANT TO STAY ON. INTSTRUCTIONS SAY UNIT WILL PROMPT BUT NOTHING HAPPENS. IS THERE SOMETHING ELSE...
Yes!!! Please charge the unit overnight. You didn't say what model you have. If it's a 2xx series, plug in the charger and move the on/off switch momentarily to the left until you see the screen say charging. Set the unit down and the screen will go off. If you touch the screen again, it will come on. After charging is done, when you touch the screen it will say charging is complete. Remove the charger. If its' a 3xx or 6xx product, hold down the on/off power button until you get the charge screen.
- Jim
SHARCNET-USA
Dec 11, 2008 | Garmin GPS
How do i charge my garmin 750
Plug the charger into the mini-usb jack. The unit should turn on and when you come to the main menu, you should see a lightning bolt over the battery bar graph. This indicates that it is charging. If you don't plan on using it and want to charge it over night, if your Nuvi has a push down power switch on the top, press and hold it briefly until it goes to a black screen and says charging. If your Nuvi has a slide switch, slide it to the left until you get the same charging screen. A few seconds later, the screen will go dark but if you touch the screen, it will light up again and say its charging and go dark again. After several hours, when you go to touch the screen it will say Charging Complete". Yiu will also notice then when you go to use it, you will see ALL of the green bars on the battery bar graph will be lit.
- Jim
SHARCNET-USA
Dec 05, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Forerunner 201
Try a reset. Hold the reset and power button for 30 seconds.
Mar 11, 2008 | Garmin Forerunner 201 GPS Receiver
GPS Logo
99 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
