Question about Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range
Kenmore Elite F1 problem
What is an F 1 problem and how do I fix it?
Thanks
  • 15,935 Answers
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 29, 2010
Fl4 problem, kenmore elite won't spin or drain anymore.
EEPROM Error
The Central Condrol Unit (CCU) receives it's data from an EEPROMonboard the CCU.
If there is an error reading this data, it will cuse this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
Check CCU
So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
May 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Aluminum melted on bottom of double oven Kenmore Elite
Scrape it. DO NOT USE until it is removed.
Oct 18, 2009 | Kenmore Elite 45986 Front Load Washer
1 week old double oven Kenmore Elite - aluminum foil melted to bottom of top oven - how to fix? Can I still use the oven?
You'll have to scrape it off. Do not use until foil is removed.
Kenmore elite refrigerator freezer won't close tight.
Head over to the manufacture's website. www.searspartsdirect.com
Enter your full model number in, and you can see expanded diagrams and part ordering information.
Sep 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Please warn folks with a Kenmore Elite front loader do not use the Purex 3 in 1 sheets. They get stuck in drain and pump!! I fixed it but it was a pain.
Thanks for the tip. You have have shared it with the entire WWW.
Jul 24, 2009 | Kenmore Elite HE4 Electric Dryer
The wash load dial is loose on the Kenmore Elite
Purchase a new one. It is slip/pressure fit. If it is loose - the hole is dogged out and it cannot be repaired.
May 31, 2009 | Kenmore Elite 45986 Front Load Washer
Error code on kenmore washer
LG washing machines indicating error code CL may have the child lock activated.
Try holding down the temperature and eco/rapid options together to turn off child lock.
Some LG series use "TEMP and OPTION" at the same time.
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
Did you ever get a response about your kenmore elite microwave touch screen?
The F2 error code on your microwave oven is a membrane failure.
It is recommended that you replace the membrane first & if you still have problems to replace the control board.
Jul 06, 2008 | Kenmore Elite 21086
Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range Logo
233 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
