Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
Mixer stopped turning when I was making bread
My mixer has made a grinding noise for a while. Today at the end of the mix cycle with my batch of bread, it froze up--it was trying to turn the dough hook, but nothing happened except a hum. I removed the bowl and hook and got the motor turning again. With just the hook on (not kneading anything) it turned. When I put the hook back in the dough, it didn't make a complete revolution before freezing up again. I would like to know if there is something at home I can do to fix this or where I can take the mixer locally to get it fixed.
  • knewght Oct 05, 2008
    I was kneading a double loaf as well.  No odd grinding noise, just regular noise of a heavy load and then it just stopped.  Haven't been able to get it started again.
  • arianne_niel Dec 01, 2008
    I've had the same problem. My mixer just stopped in the middle of making rolls and will no start again.
  • 118 Answers
You probably have stripped the gear in the head section. It can be replaced, but I would consider this a advanced repair since you need to push steel pins out of the shafts to replace the gears. Use google to find a local repair shop, or fix it yourself if your mechanically inclined, parts are available online (and not that expensive).
Posted on Nov 30, 2008
3 Suggested Answers
clyde2j2
  • 137 Answers
SOURCE: bread dough hook slips when mixing
This is not a solution but I think you have a serious problem you might have sheared some gear teeth whent the mixer jammed and it only manifests itself under a heavy load, I would take it to a repair guy, those mixers are expensive and it would be worth it.
Posted on Mar 28, 2009
  • 145 Answers
SOURCE: KitchenAid 600, Stand Mixer -
If the beater is grinding when it meets resistance, it generally indicates that an internal gear has broken or been stripped.
With the Professional 600 stand mixer, up to 14 cups of white flour or only 8 cups of any flour are recommended at one time. Speed 2 is the only speed that should be used for bread dough and it should never be kneaded for longer than 7 minutes. Failure to do any of these things make cause problems for the mixer motor.
If you are interested in self-repair, I recommend mendingshed.com. They have internal parts available to order and also have a .pdf file for the Kitchenaid Mixer Service Manual.
If you are interested in a repair facility, please visit the following link:
http://caservice.kitchenaid.com/
This is a listing of certified repair locations.
Also, if the mixer is less than a year old, Kitchenaid may replace it under their 1 Year Manufacturer's Warranty. I would recommend calling their customer service. Their toll-free telephone number is:
1.800.541.6390
Posted on Jul 16, 2009
Kg25h0x stand mixer
Sadly the only help we can give is SUGGESTING you contact Kitchenaide and have them assist you
Oct 17, 2017 | KitchenAid Professional Heavy Duty Series...
Kitchenaid mixer 600 won't turn on
bread is very tuff on mixers. always buy the strongest mixer that you can afford. im guessing the field in the motor fried.
Feb 07, 2013 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
Mixer arms shake when kneading bread
You have not supplied a model number and the bowl lift models are not all the same. A couple of items you could check, make sure that the bowl retaining clip that engages with the dimple on the pedestal side of the bowl is not broken. Make sure any bolts/screws holding the pedestal to the base or the pedestal to the motor are tight. Even if you supply a model number I can't think of anything else to look at unless the handle is not lifting the bowl up tight enough. I think on some models the arm holds the carrier up with some pressure which would help stop the wobbles.
Jul 13, 2017 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
2 weeks ago I bought my mixer. It sounded very smooth. I made 1 batch of 4 cup bread, 1 batch of 8 cup bread, and whipped cream twice. Now it is making a rough, whining, grinding noise. It isn't the...
That could be gears or the motor or the connector to the mixer head etc. Since this is two weeks old I wouldn't even worry about what just take it back and get a replacement. Even the new kitchenaids are very good and very realiable after years of use and abuse. Abuse is something like Dad I tried making sand from some rocks. Still worked after that btw.
You just got a bad unit which from my experience has been pretty rare. It will be under warranty so just get it replaced and enjoy the new one for years to come instead of worrying about this one.
Feb 27, 2011 | KitchenAid KV25G0X Stand Mixer
I make bread in my 620 series mixer and
Remove the upper hslf of motor housing (unplug first) and ck it out. If all looks ok, put some food grade grease on the gears and mix on! If there is alot of metal, the gears are worn and should be replaced. If you order gears, order brushes also. The carbon blocks with springs behind them on opposite. end. They really are quite simple once you get into it. Good uck.
Aug 22, 2009 | Food Mixers
KitchenAid 600, Stand Mixer - Loud grinding noise, happened when mixing bread dough. When bowl is lowered (dough hook disengaged)....no noise, hook turns. When bowl is raised so that hook engages dough,...
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
Jan 31, 2009 | KitchenAid KP2671 Professional 6 Series...
My mixer was straining to stir bread dough. Now the motor turns on, but the arm does not rotate.
Did you hear a CRACK sound just as the mixer stopped running? If so, the plastic transmission housing may have failed & destroyed the worm gear and the front and rear bearings and possibly deformed the bearing seats as well. It happened to me. Although these machines are marketed stating that they can knead bread dough, they can't. Mine failed 5 months out of warranty, after only30 batches of Sourdough Bread. Take the top cover off of the mixer and look for the transmission housing near the front of the mixer. If there obvious cracks in it, it is your problem.
Dec 03, 2008 | KitchenAid K45SS Classic Stand Mixer
Grinding Noise
If it's metallic sound you are loosing teeth on a gear or two.  This is caused by lack of lubricant or simply fatigue of the material of the gears.  Don't use it, you can get metal flakes in your food.
Take it in to a repair shop and have it fixed.  The money spent is well worth it because if done correctly will last another 12 years.
Oct 21, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Kitcchen Aid mixer making a grinding noise
common problem. Worm gear & bracket #PS734273 about $36.
Oct 21, 2007 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
411 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
