Question about Whirlpool Refrigerators
When I use the water dispenser on the outside of the freezer, the water doesn't shut off in time when I take away the glass & therefore water runs down the front of the frig & onto the floor. (Whirlpool Gold Conquest)
  • 3 Answers
Possable broblem with water volve,but you need to cal to professionals
Posted on Sep 26, 2008
Why would ice from the front door have an off taste but the ice in tray in the bottom freezer tastes fine?
I don't see from the literature that this model dispense ICE from the "front door." The dispenser on the left door seems only to dispense water. In your configuration the water comes through a completely closed system until it reaches your glass and should therefore not have an order or taste different from that of your cubes in the bottom Freezer.
Nov 25, 2015 | LG LRFD22850 Bottom Freezer Refrigerator...
The ice dispenser keeps going after I remove a glass.
does the ice auger still move(motor) or does the ice just fall out for a few moments after you release the drinking glass trigger ?
reason I ask is: there is a mechanical clock spring motor inside that controls a door to shut off the freezer from the outside(kitchen) , and ive seen rust/time ruin many of them (sticks open) there not too expensive and not too hard to change , usually just two Phillips head screws
this is not well for a few reasons , 1 it allows ice to continue to fall out of freezer and 2 it never shuts the freezer off from the kitchen so appliance runs more to freeze the freezer , also it makes for some drips on floor as well from melting ice
Oct 01, 2015 | Frigidaire Refrigerators
I changed my filter, PUR 4396841 and now it is vibrating when I stop dispensing water. Any suggestions? Do I have it installed correctly?
The vibration is a tiny bit of "water hammer." Previous to your filter change, the water flow was restricted, and therefore incapable of causing water hammer. Now that you've changed the filter, the flow is large enough to cause a little water hammer when you shut off the flow.
How to fix: shut off the flow SLOWLY. Water hammer is caused when the flow of water is shut down quickly. This is just as true with large flows (as in fire engine pump panels), as it is in itsy bitsy
filtered water lines & filter housings.
May 13, 2011 | Whirlpool 4396841 Whirlpool Refrigerator...
Kenmore refrigerator, has water dispensor on front, when you put the glass there to dispense it will not stop flowing, you have to bang the door shut
Sounds like the water activator switch is sticking. It may help to clean the area where the switch is including the hinge. Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Since shutting the door stops it the above is most probable but the water inlet valve on the back where the water supply comes in could be sticking.
Sep 01, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Not getting cool water from dispenser in door
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 28, 2009 | Samsung RS2534 Side by Side Refrigerator
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
No water at door
I have a 3 year old GE GSL25 refrigerator with the water/ice dispenser on the freezer door. Even when setting the freezer at 2 and turning the fridge's lower drawer to the warmer "cheese" setting, the water dispenser line would freeze every few weeks. If you have this problem, first verify that the water filter (back of the fridge) is not clogged and that water flows from the water line at the bottom left corner of the freezer door (disconnect and press water delivery dispenser-see owners manual).
I used the hair dryer recommendation to unfreeze the line by heating the flat area of the freezer door directly behind the water dispenser area (~10 min did it). The trick to keep it from freezing up again involved buying a cheap foam sleeping bag mattress (~1/3 inch or 1 cm thick) made of a polyurethane foam (pretty dense). I cut it to match the flat area of the freezer door behind the water dispenser and taped it to the door with packing tape. For the past 3 weeks (even with freezer at #4 setting), my water is flowing freely. Personally, I think this solves a product defect with insufficient insulation in the freezer door near the dispenser water line.
Jan 01, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Dec 31, 2007 | Refrigerators
Refrigerators Logo
46 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
