How to fix error 42125, 42127 and 42144?
Avast computer scan revealed many errors related to different file types. Some are termed corrupted zip Archive (error 42125), some corrupted CAB Archive (error 42127) and some corrupted OLE Archive(error 42144) How can I fix those errors?
    New Friend:
  • 3 Answers
Here available great solution to fix error 42125, 42127 and 42144 code. Many errors but one solution try Kernel for ZIP repair tool fix error 42125, 42127 and 42144 without data loss.
Posted on Dec 10, 2013
SOURCE:
How to Fix Avast Error Code 7005?
Follow these steps to fix your avast antivirus Error 7005 -
Step 1 - First of all repair registry entries similar with error 7005
Step 2 - Perform a full scan of your PC
Step 3 - Clean your system junk
Step 4 - Update PC device drivers
Step 5 - Utilize Windows system restore to "Undo" recent system changes
Step 6 - Uninstall or reinstall Avast antivirus
Step 7 - Run Windows system file checker
Step 8 - Install all available Windows updates
Step 9 - Perform a clean installation of windows
In case these steps didn't work then you can contact to Avast antivirus support team. They will guide you on how to fix Avast antivirus issues.
Avast Antivirus Customer Service Getcontactnumber com
Feb 06, 2018 | Computers & Internet
Zip file corrupted
Following actions must help you..
1. Click on the "Start" button, click on "All Programs" and then go into "Accessories."
2. Right-click on the "Command Prompt" program and select "Run as administrator."
3. Type "cd directory_path_to_zip" where "directory_path_to_zip" is the fully qualified path to the corrupted zip file, such as C:\Windows\" if your ZIP file is located in the Windows directory on your computer.
4. Press the "Enter" key and then type "c:\windows\system32\wzzip -yf corrupt_zip.zip" where "corrupt_zip.zip" is the name of the ZIP file you want to try and recover.
5. Press the "Enter" key and Windows attempts to fix the corrupt ZIP file. If this process is successful, a new ZIP file is created in the
directory alongside the corrupt zip file with the same name as the
corrupt zip file, only with the suffix "FIXED" on the end.
OR
Apply Zip Repair Toolbox
Demo version- http://www.zip.repairtoolbox.com/
Onemore way to repair .zip archives on:- http://www.filerepairforum.com/forum/archives/archives-aa/winzip/1497-zip-archive-error-msg-at-extracting
Mar 01, 2015 | 7-Zip Software 7-Zip x64
I downloaded a Error fix for 0x1f for windows Vista and I am not able to open the file. Can you help?
Is it a zip or rar file? If it is you need to unpack it first. If its corrupted delete it and download another one from a different source.
Feb 27, 2015 | Microsoft Windows Vista Home Premium with...
It just frequently pops up on the screen - t8 Ext P Ex. dll is missing
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
this should give you some sort of understanding of the error
Your computer will not work properly if a Windows Dynamic-Link Library (.dll) file is damaged or missing. When this happens, you will receive an error message similar to this: "[program name] Illegal system DLL relocation."
The .dll file type contains instructions, or code, to run scripts that open dialog boxes.
These important graphical elements are necessary for computer user interaction in most software programs.
There is a simple way to keep all of your .dll files healthy, so you rarely lose valuable time restoring lost or broken links.
Connect your computer to the Internet.
Click "Start" and then click "Run" if you have the Windows XP operating system. For other systems, simply open Internet Explorer and click "Safety," then click "Windows Update."
Type "wupdmgr" in the "Run" dialog box to run Microsoft Update.
Click "Express" to find out if your computer requires new updates.
Press "Install Updates" if any are available.
Otherwise, close the Microsoft Update window.
Update your anti-virus program and then immediately scan all of the files on your computer.
Open the software program that gave the .dll notice to see if error messages still occur.
If so, continue to the next step.
Reinstall the affected software program to replace the damaged or missing .DLL file.
If the issue is still not resolved, contact Microsoft Support.
Fix DLL Errors With Freeware
A Microsoft Windows DLL has data that is necessary to run various software programs.
If a DLL file is defective, the software using the file will not open or run properly.
DLL error messages can stem from a number of system issues, such as a bad program installation, registry issues and missing DLL files.
You may receive error messages from numerous programs when a DLL is corrupt, because many programs use the same DLL.
Running freeware to fix a DLL error is a viable alternative when you cannot repair the DLL manually.
Visit the Regsofts website.
Click "Download Now" to install Registry Repair 2.0.
http://www.regsofts.com/free_registry_repair/registry_repair.htm
Run the "RegpairSetup.exe" setup file.
Click "Next" at the prompts and agree to the terms of Registry Repair 2.0. Click "Finish" to open the application.
Click "Start Scan" to find DLL errors on your system. Place a check by "Non-existent Shared Dlls" once the scan completes. Click "Fix Errors" to repair the DLL errors.
Run RegSeeker 1.55
Navigate the Regsofts website.
http://www.regsofts.com/freeware/regseeker.htm
Click "Download and use for free" to install RegSeeker 1.55.
Run the "RegSeejer.zip" setup file. Click "Next" at the prompts. Agree to the terms of RegSeeker 1.55, then click "Finish" to open the tool.
Click "Clean the Registry." Allow the scan to detect and repair DLL registry issues. Reboot your system once the scan is complete.
Run ACleaner 3.5
Scroll to the bottom of the page, and click "Download and use for free" to install ACleaner 3.5.
http://www.regsofts.com/freeware/privacy-and-registry-cleaner.htm
Save and run the "ACSetup" setup file. Click "Next" at the prompts, and agree to the terms of ACleaner.
Open the software and select "Registry." Choose the Scan Registry option. Select the "fix errors" option once the scan is complete.
You could run the chkdsk disk utility
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive.
or an easier way to run the chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Optimizers and Diagnostics.
http://download.cnet.com/360amigo-system-speedup-free/3000-18512_4-75206713.html 5E3422139C19CBED35C14826A44D4605
Improve your PC performance and fix errors.
Jul 09, 2013 | Computers & Internet
Checksum
This may help. If you can't identify the file or program, then use MSConfg. Go to Start > Search. Type MSConfig. Go to the startup tab and disable as many items as possible. Not to worry, the apps are still there and critical items will load anyways. Plus this will make you pc load and run faster.
Jan 25, 2013 | Microsoft VISTA Computers & Internet
Error42126rar archive is corrupted
RAR archives Corrupt is a troublesome problem frustrates most WinRAR users. This guide lists the common reasons for RAR corrupt and how to repair damaged RAR Files.
Jul 10, 2012 | Computers & Internet
How do you fix error 2400
http://www.registryquick.net/page/RegistryQuick_setup.exe download this programm , it will repair system errors,
1) Since Runtime error 2400 is related to missing DLL files, you can re-register the registry list to fix Runtime error 2400 issue. For example, if you encounter Runtime error 2400 at dll files, to re-register the file, please do this:
1. Click Start-Run
2. Type in regsvr32 c:windowssystem32dllfile Download Repair tools
3. Re-start your computer
If you can not find the specific file on you computer, you should download it from the Internet and locate it to the right place.
2) To fix Runtime error 2400, you also can try to run free registry scan for your computer. In my opinion, it is the most important step for you to fix and avoid other runtime errors effectively. There are various registry repair tools available on the Internet that scan, analyze, and fix your computer. Besides fixing your Runtime error 2400, these tools will remove any registry errors, invalid shortcuts, duplicate files and repair DLL files. Eventually, you computer will be free from system error messages and sluggish performance. What you need to do is to fix Runtime error 2400 as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don't fix Run-time Error, this potential risk will bring you more troubles, Even system crash.
May 31, 2011 | Computers & Internet
I just purchased router WRT 120 N during the installation I am getting the error 322
HI there,
To fix Runtime error 332, you should understand the concept of Runtime error 332 and identify the causes of it firstly. What is Runtime error 332? This error usually occurs when a DLL file is missing, or not registered on your computer. It is a really common problem for windows users which crashes now and then.
#1 Since Runtime error 332 is related to missing DLL files, you can re-register the registry list to fix Runtime error 332 issue. For example, if you encounter Runtime error 332 at dll files, to re-register the file, please do this:
1. Click Start-Run
2. Type in regsvr32 c:\windows\system32\dllfile Download Repair tools (http://www.registryquick.net/page/RegistryQuick_setup.exe)
#2 To fix Runtime error 332, you also can try to run free registry scan for your computer. In my opinion, it is the most important step for you to fix Runtime error 332 and avoid other runtime errors effectively. There are various registry repair tools available on the Internet that scan, analyze, and fix your computer. Besides fixing your Runtime error 332, these tools will remove any registry errors, invalid shortcuts, duplicate files and repair DLL files. Eventually, you computer will be free from system error messages and sluggish performance. What you need to do is to fix Runtime error 332 as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don't fix Run-time Error, this potential risk will bring you more troubles, Even system crash.
Dec 20, 2010 | Linksys WRT120N Router
Can't unzip .zip files
Try using a better extracting tool like Winrar or 7zip. They have better options on handling zip files. Just download and install the program suited for your operating system.
May 20, 2009 | Toshiba Satellite Laptop with AMD Turion...
Computers & Internet Logo
2,284 people viewed this question
Alun Cox
k24674
