Question about Kenwood Audio Players & Recorders
Cannot connect ipod to KVT-522DVD. I am using the KCA-IP300v. I have updated the firmware to 1.4.0. But I still cannot get control of the ipod
    New Friend:
How did you manage to update your headunit to 1.4? I have the same unit and it will not accept the update. Can you help please? My email is akerfpg@hotmail.com. cheers
Posted on Jul 21, 2014
    New Friend:
Hello. Thanks for everyones help. I went around to a dealer to explain the problem and they spotted that the connection lead was not a genuine one. I had been missold this item as being a genuine item. I bought a geniune lead and everything works fine now.
Thanks once again.
Paul
Posted on Sep 28, 2008
I have a 4th Generation iPod 32gb and it won't play sound when o hook it up my kenwood kvt-516
make sure that you have updated the kenwood to the latest software for the ipod--at kenwoods site--What cable are you using to hook up to the kenwood, hope you are not using the usb cable cause that won't work , you have to have a KCA-Ip301V ipod video cable. Here is the firmware link you need-- http://www.kenwood.com/cs/ce/mm/firmware/2010/2010c/eng.html
Dec 27, 2010 | Kenwood DDX516 Car Video Player
I plug my ipod to the stereo but my stereo screen still says discconected
you have to go to the kenwood site and download the firmware update go to this page http://www.kenwood.com/cs/ce/mm/firmware/2008/eng.html
after you download the file unzip it and burn it with either nero or roxio, as a data file insert the cd on your kvt-512, if it reads DISK ERROR, press the reset button on the front of the stereo, once the screen comes back up select the DVD function, the system update should start from there. let it finish once it does then you'll be able to plug in your ipod. oh and ofcourse for this you should know that you need the ipod adapter, depending on what you want to do with it for instance i have the KCA-iP300V which allows me to view videos from my ipod as well.
Jan 27, 2010 | Kenwood KVT-512 Car DVD Player
Kenwood KVT-512 iphone compatibility
Just ignore the airplane mode prompt and if your wiring is correct everything should work.
With my BMW I had to connect both the solid blue (pwr ant) wire and the blue with white stripe (p conn) to the solid blue wire from the factory harness.
It isn't obvious that either of these are needed as the KVT-512 has it's own power supply but the way most factory power amps are installed the power from the KVT-512 is not used and the car manufacturers power amp needs to be turned on.
If you are listening to the radio the pwr ant wire will turn on the power amp, this didn't seem obvious because the BMW doesn't have a power antenna. And when you are using the DVD player or the iPod connection you need the P Conn wire to turn on the car power amp as the ant pwr is disabled because you are no longer using the radio and Kenwood assumes you will not need the antenna so no power to this lead.
Solder all three wires together and you should have sound all the time.
Jul 01, 2009 | Kenwood KVT-512 Car DVD Player
KENWOOD KVT-729DVD & KCA-BT100 BLUETOOTH + KCA-IP300V
Try this. This is the Kenwood support. Hope this helps. :)
By Phone
(310) 639-9000
or toll free 1-800-KENWOOD (536-9663)
Jan 13, 2008 | Kenwood KVT-617DVD Car DVD Player
How do i connect my itouch to kenwood kvt-512???
Hi there! You need a Kenwood KCA-iP300V iPOD VIDEO DIRECT CABLE.
Feb 09, 2009 | Kenwood KVT-512 Car DVD Player
Can the firmware on a in dash kenwood dvd be change
Visit www.kenwoodusa.com for latest firmware updates. Some of the updates are specific to map software (Garmin for KNA-G510) or bluetooth (Parrot for KCA-BT200) only.
Aug 10, 2008 | Kenwood DNX7100 Car Video Player
146 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
