Question about Canon PIXMA iP90 Mobile Printer
Put new color tank refill says' close lid' lid is closed
I have refilled this printer's tank many times. #15 size. It is 2 years old. Is it dead?
    Guru:
  • 558 Answers
Please add a new Cartdridge to your Printer and then try.
Check also the device manager.
Check the printer independely, after unplug from PC.
Let me know if I can assist you further.
Regards
Ellin
Posted on Sep 26, 2008
Cannot print
Change the cartridge ...
but, in case E3
I have workaround for the empty tank issue:
- buy or borrow another not empty tank
- place it in
- start the printer
- it recognises the "new" tank
- turn off the printer
- put back the old, empty, but refilled tank
- turn on the printer
- print something
- it will pop up a dialogue window saying
"The ink level of the black/color tank cannot be
determined. The ink level determining function will be
disabled for the black/color tank.
If you want to continue printing without this function
press the Start button on the printer."
- Press the Start button on the printer and ignore the
button 'Cancel Printing' appearing on the dialogue window.
- The dialog window disappears.
You can print your refilled tank as many times you want from this time.
When you go to 'Printers /Canon /Properties /Maintenance / Printer Status / Ink Information' it says that the ink level measuring function has been disabled for: black [40] / color[41]. You can ignore this this message, the printer will work perfectly without this stupid function.
Mar 18, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Tip
Upgrade your printer and continue to refill your own ink cartridges
I just had my HP 8600 document feeder fail. This problem part cannot be ordered for replacement, and to have it repaired will cost almost $200. Well a brand new one on sale is only $250. And better yet, upgrade to the HP Officejet Pro 8630, since HP will no longer be manufacturing the 8600.
I have saved hundreds of dollars, refilling my own cartridges. I upgraded, after I learned that the newer model uses the exact same ink cartridges. So, I am on my third HP Printer, and I have purchased only one set of cartridges in 3 years. I have refilled my color cartridges at least 8 times. They need refilling more frequently than the black. (The black ink cartridge is twice the size.)
In addition, I purchased a three year extended warranty for $20 or $30. If anything happens to this printer in that time, it will be replaced automatically, and I will not have to pay for shipping.
In essence, I am in position to have used the same set of ink cartridges for 6 years. I only put my new cartridges in after I have refilled the empties. After the printer resets, I pull them out and put in the refills. So you see, my printer came with a set of cartridges, and I purchased one extra set, for resetting the printer after refilling the cartridges.
I suggest to really control your costs, consider buying a quality printer, that will be good for years of service, add a service contract, and refill your own cartridges. If you print as much as I do, you are realize a significant savings in the cost of ink.
I know that I have saved a minimum of $360. Add the cost of inconvenience and going to Walmart for refills, and you may be realizing a savings of $150 per year, just for refills.
Good luck, and plan ahead.
on Mar 04, 2015 | HP Officejet Pro 8600
How to refill a canon lbp 2900 printer cartridge
  1. Remove the old ink jet cartridge from the printer following the manufacturer instructions. Close the lid on the printer to keep it free from dust and debris while you are refilling the Canon ink cartridge.
  2. 2
    Locate the ink tank on the cartridge. Put a 3mm drill bit in a drill. Drill a hole in the top of the ink tank on the cartridge.
  3. 3
    Gently insert the needle on the bottle of ink into the hole you just drilled in the ink cartridge. Avoid squeezing the bottle until the needle is completely inserted in the ink tank.
  4. 4
    Squeeze the ink bottle gently to refill the cartridge. Fill the tank with a little at a time until the cartridge is full.
  5. 5
    Remove the needle from the ink tank. Wipe the top of the Canon ink cartridge off with a paper towel. Place a small piece of duct tape over the drilled hole. Rub the tape to remove air bubbles and to make sure it adheres to the cartridge.
  6. 6
    Put the refilled ink cartridge back into the printer. Clean the head of the printer by running the printer software and following the instructions for head cleaning.
Nov 10, 2010 | Canon LASER SHOT LBP-2900 Printer
How to refile the cartridge of canon pixma ip1300 printer
Instructions :
  2. Locate the ink tank on the cartridge. Put a 3mm drill bit in a drill. Drill a hole in the top of the ink tank on the cartridge.
  3. Gently insert the needle on the bottle of ink into the hole you just drilled in the ink cartridge. Avoid squeezing the bottle until the needle is completely inserted in the ink tank.
  4. Squeeze the ink bottle gently to refill the cartridge. Fill the tank with a little at a time until the cartridge is full.
  5. Remove the needle from the ink tank. Wipe the top of the Canon ink cartridge off with a paper towel. Place a small piece of duct tape over the drilled hole. Rub the tape to remove air bubbles and to make sure it adheres to the cartridge.
  6. Put the refilled ink cartridge back into the printer. Clean the head of the printer by running the printer software and following the instructions for head cleaning.
Good Luck!
Aug 28, 2010 | Canon PIXMA iP1300 Printer
Replaced the ink. black works colored does not.
Normally, new catridge has a thin layer close the output of the ink. See that thing. If it close, pull it over, Or.
May be the catridge is not suitable with the printer.
May be the the catridge is quite old and the ink is dry, if it is refill catridge, put several drop of hot water in it.
Hope this may help.
Jan 20, 2010 | HP DeskJet F380 All-In-One Printer
Printer (HP5650) has full ink cartridges.window sez almost empty
That is normal, the printer "sees" the cartridges by their serial number, so when you pop in a refilled cartridge, the printer thinks you have put in old cartridges and continue to show low ink level. When you pop in a new one, with a new serial code, the ink level will reset, showing that the cartridges are full again.
You can try this:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
Doesn't always work, but you can try.
Here are links, so you can see:
http://www.misterinkjet.com/hp56reset.htm
http://www.misterinkjet.com/hp57reset.htm
Hope that helps!
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
Refilling lexmark cartridges x2500
Hey....I solved the lexmark out of ink problem!!!HA!!! what you have to do if you want to refill these is "pop" off the top of the cartridge. It is not easy as it is glued down...using a small screwdriver preferably a small flat jewelers screw driver you can peel back the plastic that seperates the "lid" of the ink cartridge. you have to use a little force but you can get it off. Once you do this the cartridge will always read full!!!!!! just tape it or super glue it back on. You never have to take it off again! although I recomend cleaning the ink sponges inside every 3 refills. but this works great.....ha ha lexmark.....I got ya!!!!
Jun 03, 2008 | Lexmark X2500 All-In-One Printer
Losing Ink
Depending on how many times you have refilled the wells of the cartride the sensor inside may be going bad as the manufature of the cartridge only intended it for a one time use. My recommendation would be to buy a off brand compatible and refill those.
Mar 07, 2008 | Canon BJC 8200 Photo InkJet Printer
Dell AIO 940 printer refilled cartridge
  1. Make sure the printer is turned on.
  2. Lift the printer's front cover.
note.gif NOTE: The ink cartridge should be in the up/loading position unless the printer is busy.
  1. Squeeze the tabs on the cartridge lids and lift the cartridge lids up. The cartridge pops up when the lid is fully lifted.
  2. Remove the cartridges.
  3. Check and make sure that all of the protective tape has been removed from the contacts on the ink cartridge.
  4. Replace the cartridges.
  5. Snap the lids closed.
  6. Close the printer's front cover.
  7. When prompted on the printer's LCD to choose New or Old, choose Old.
  8. Press the Select button.
This was from Dell's website
Nov 08, 2007 | Dell A940 All-In-One InkJet Printer
Canon ink tank problems
I think I figured this B!tch out.
When you get the error:
"More than one ink tank of the following color is installed" or
"Ink cartridge not recognized"
Open up the lid where the cartridges are and hold done the "SEARCH" button. This has been working for me, and I bought my ip6600d in 2005, so my machine is old, and ready for this..........ORIGINAL INK!!! Never really used it beyond printing very few pics. So I was really pissed when I found these messages to almost 5 years after buying this printer. So to recap, open the lid where the ink cartridges are while holding the "SEARCH" button, hold it up for like 5 to 10 seconds, place lid down still holding the search button, then let go of the search button. I did notice the alarm was lit, but went away after I released the search button. Good Luck!!!
Until I held the search button down I had turned of the printer, reseeded the cartridges and open and closed the lid but it never worked.
Sep 19, 2007 | Canon Pixma iP6600D InkJet Photo Printer
Canon PIXMA iP90 Mobile Printer Logo
29 people viewed this question
old marine
old marine
