Question about Pelonis WM-HO202C Oil Filled Radiator Heater
Just stopped working
Worked and now it doesn't.
light does not go on- and does not produce heat.
does it have a overheat setting that could have tripped a fuse
inside the unit?
notice on side says not to open side cover.
  • 3 more comments
  • mzickria Nov 15, 2008
    I am looking to replace ON/OFF switch. Where can I get one
  • jmw63049 Jan 11, 2009
    It just quit working? What is the problem?
  • Anonymous Jan 17, 2009
    on - off switch does not work
  • tracyeddie Jan 27, 2009
    my heater just stopped producing heat. Power light comes on very faint, with the thermostat on a very low setting. When I turn the theromstat up at all the power light goes off, and there is an audible click.
  • titan2009 Feb 15, 2009
    STOPPED WORKING. HAVE POWER TO THE THERMASTAT AND ONE SIDE OF THE HEATER COIL.
I have the same problem. was working great for one week then it just stopped working. really pisses me off how things are made so badly these days. there is no reason why something should break after using it for a week. any soultions before it goes to the curb??
Posted on Nov 22, 2008
It is my first time using it, I brought it from USA and it is not working at all!!
follow this steps and fix it. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the electric cord and check the thermostat .
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat
If the iron does not spray properly, inspect and clean the nozzle
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Jun 11, 2013 | Black & Decker Irons
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
My 97 eclipse (2.0L 4cyc/ no turbo) starts to over heat when i come to a stop like at a light then cools as soon as i start moving. I flushed radiator and changed thermostat. No loss of water or oil? It...
how much does it go up to ? could be an air loc in the system or fauty switch ?is the electric fan working ?if its a auto it will rev higher at lights with the brake on as it wants to go . try putting it in to park at lights etc ?
Sep 07, 2011 | 1997 Mitsubishi Eclipse
Microwave is less than a year old. It looks like everything is working, timer, light, air, turntable, etc., but it doesn't cook.
HI..there is a heating filament of an oven MAGNETRON..it s responsible of producing heat to the oven..possibly this is defective ..this filament must be replaced by a new one..theres no problem with the motor cos it runs the table power and light button seems working..HOPE THIS HELPS
Jul 06, 2011 | Oster Microwave Ovens
My MAGIC CHEF MCO153uw stopped working. It heats
This sounds like a thermal protector is turning the microwave off. If I were to hazard a guess, it would be the magnetron (produces the microwaves) is overheating causing the shutdown. If the fan was not running it would create the same condition by causing the magnetron to overheat.
Nov 14, 2017 | Magic Chef CMV1000B Microwave Oven
A Krups KM7005 coffee maker/grinder doesn't heat or drip water .
Mine had the same problem ... all the lights are on, grinding works fine, but no heat on the plate, and no dripping of water.
After a weekend on the workbench, I mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. To date, I have helped 13 people on this site fix this exact problem.
I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Dec 16, 2009 | Krups Small Appliances Espresso Machine
Heat doesn't work ..dryer spins but no heat is produced
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 01, 2009 | Dryers
Doesn't do anything
Look under control pannel for a fuse! I am not sure about your model but most of these heater types have a fuse
good luck!
Dec 12, 2008 | Pelonis WM-HO202C Oil Filled Radiator...
Pelonis WM-HO202C Oil Filled Radiator Heater Logo
614 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
