Question about Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator
Kenmore Top...Brand new, loud icemaker & door vibrating
I can live with the loud noise from the factory installed icemaker, but not the vibrating noise from the refrig door. Lifting the door and pressing inward does disrupt the vibrating; however, I cannot stand here all day. This refrigerator has been doing this ever since we bought it several weeks ago.
  • 93 Answers
You may think its comming from the door but check the back of the frige it could be your cooling fin radiater if we can say when you here the noise listen closly then touch the tubings or the radiater in the back you will find where its coming from it may be a loose scew causing vibration
Posted on Mar 15, 2009
Hi, I have a Kenmore quietquard dishwasher model number 587.14012406a and it's making a loud noise throughout the wash it then stops and then restarts which is a vibrating noise and is extremely loud!
suggestion, i suspect you have got something in the wash pump or the pump impeller is breaking up this can cause a vibrating noise or it could be the rince pump.
Nov 20, 2016 | Kenmore Dishwashers
Loud vibration
1) What brand and type water heater? Gas or electric? Tank or tankless? Or boiler? Solar assisted? Indirect? Wood-burning? Oil-fired? etc?
2) How old is heater? Is this a new installation? Or installation that worked before and vibration is something new.
3) Or are you talking about a washing machine instead of water heater? Or hair dryer? Or GMC truck?
4) Add a comment and give more exact information from label located on side of unit, for possible assistance.
Feb 18, 2013 | Water Heaters
The whurring noise is very bad,you have to close the laundry room door to hear any one talk.the noise is in the spin cycles
When the factory packs the machines for shipping they install 4 bolts that lock the drum in place. Were these removed when the Washer was installed at your house? They need to be removed completely otherwise the machine will make a lot more noise and vibrate loudly.
Dec 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Maytag Bravos dryer is brand new. It is the quiet series 300, but is the loudest dryer I have ever owned. It makes like a loud vibrating, humming noise. Is this normal? I am now drying my second load of...
People, the first words the poster said were that the dryer was "brand new". All of your suggestions assume the dryer had extensive use. This sounds like a factory defect issue!!!! My brand new Maytag Cabrio gas dryer is also making an obnoxious buzzing sound that seems to cycle on and off as the gas ignites. The buzzing sounds electronic not mechanical. What would buzz when the burner is active?
Oct 31, 2010 | Maytag Dryers
Loud noise coming from icemaker...noise decreases when i increase temp and goes away when icemaker shut off. I set the initial temp at 3 degrees, then let it make ice - after about 3 hours it sounded like...
The icemaker is pretty simple, there is a motor, a solenoid, and a couple of switches.
It sounds like the whole icemaker mechanism is jammed or has a broken gear, and the motor is trying it's darndest to turn the stuck mechanism (grinding it's gears in the process), or the gear has already gone, and what's left of the gear is dancing around in there.
http://www.repairclinic.com/Appliance-Parts?s=t-frs26r4a-%3d%3dc248
My guess is either the $7 icemaker drive gear or the $94 icemaker assembly.
Oct 23, 2009 | Frigidaire FRS26R4A Side by Side...
I have a Kenmore trio 795.7756 bottom freezer refer. has been making loud noise for days. Only stops when refer. doors are opened. I vaccumed in back, noise still there.
It sounds like the Freezer Fan and Icemaker Fan are going bad. They are located behind the back wall of the bottom freezer chest. These are very labor intensive to replace.
Jul 15, 2009 | Refrigerators
It vibrates but has this loud noise with it about every 5-10 minutes
Sounds like the compressor is going out on thermal overload. Call a service technician to look at it.
May 27, 2009 | Whirlpool 17.6 cu. ft. Top-Freezer...
Right Door is making loud popping noise
After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
Sep 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 90 Series Washer Noise--Won't spin
For Tegres
If the noise is only when there is water flowing, check tighten the screws that mount the water fill solenoid valves to the case. The solenoids operate on line current so they vibrate at 60/50Hz (local suppply frequency) if they are loose at all, the noise is loud the body acts as resonators
For SRONEAL, that symptom describes coupling failure exactly, have you removed the coupling to check, often times the motor side hub is stripped, but there is no visible external damage
Jul 23, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator Logo
377 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
