Question about Refrigerators
I have a 8 year old amana fridge model #SQD23VE we had a power outage about 1 week ago and the fridge has not been cooling properly since i hear the fans running but no ice is being made and things are not freezing i have cleaned the coils and still are having the same problem help!!
  • ecol Dec 06, 2008
    i have a 8 year old amana fridge model #SQD23VE we had a power outage about 1 week ago and the fridge has not been cooling properly since i hear the fans running but no ice is being made and things are not freezing i have cleaned the coils and still are having the same problem help!!
  • 943 Answers
Hi thanks forr the question so you cleand the coils inside the freezer and at the back by the compressor and was the compressor running . if it was and still not cooling you have a compressor problem
Posted on Sep 27, 2008
Fridge/ice maker not cooling but lights on and fan is running. How to check if it can be repaired or not?
Unless you tell us what the unit is doing and not doing you might as well just go out and pound some salt!
Nov 22, 2015 | Refrigerators
Four year old amana side by side has stopped cooling. Sounds like compressors is not kicking on. what's wrong?
Unplug it for 30 minutes to an hour and it should start up again. Problem is your compressor is no good. Get ready for a new fridge in 3-6 months.
Jul 25, 2012 | Amana Refrigerators
Refrigerator not cooling...makes hissing noise
From your problem description I would say it sounds like maybe the condenser fan is not running. If that fan does not run, the compressor will overheat, and get very unhappy, LOUDLY. There is a fiberboard cover on the back of the unit, unplug the unit, remove the cover and inspect the fan, it should turn freely if you nudge it with your finger. If it does not turn freely, you will need to make it so by lube, removing foreign object (dead mouse once for me) dust dragons etc... or replace the fan if necessary.
Dec 16, 2009 | Amana Refrigerators
Not Cooling at all
unplug , put 1 foot from your fridge and the wall , wait 15 mins, and plug back agin ooooooooooooh you will enjoy. thank you
Sep 16, 2009 | Amana BX21V
Clicking, buzzing, compressor too hot, thawed out
Sounds like the compressor is in thermal overload. Let it cool down completely and meter the starting amperage on start to run. The compressor could be seized or it's windings could be shorted to ground (checking the resistance between the windings terminals on the compressor while unplugged will determine this.).
Jul 14, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
MIni fridge stopped working/cool.
I got mine in 2005. It stopped working 4 or 5 weeks ago. It made a clicking noise and the compressor was very hot. Compressor is under warranty but appliance repair shop wanted $125 to install it and another $75 to charge it with freon. I saw a posting somewhere else that said it was a relay switch. I ordered one from RepairClinic.com for $24.00 incl. shipping, put it in and it's working now. There's a black plastic housing on the left side of the compressor. Just unscrew that, pop the cover off (that was a little tricky) and plug in the new part. Maybe I'll get another 3 years out of it.
Jun 29, 2009 | Magic Chef MCWC16MCG Wine Cooler
Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Mar 06, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
155 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
