Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool Washer mod.LSR5232LQ1
WASHER WILL NOT ADVANCE TO NEXT CYCLE AFTER AGITATING.I HAVE REPLACED THE TIMER AND IT DIDN'T FIX THE PROBLEM.IT WILL NOT SPIN,RINSE OR DRAIN.I WAS WONDERING IF YOU COULD HELP ME.THANKS!!
  • wowhow Oct 13, 2008
    My LSR7233 won't drain either. It does agitatale, but not drain and advance to next cycle. Have tried back washing the drain line, and water raised in the tub, but still no drain.
  • dperry5 Mar 08, 2009
    Yes, I have the same problem. The washer will start and run in any setting but once the washing stops, nothing happens. Same thing if in rinse cycle, once the cycle is done the machine just stops. It will not advance to the drain spin cycle.
    Genius:
  • 1,028 Answers
Ck lid switch
Posted on Sep 27, 2008
  • zamboniguyy Jul 14, 2011
    sure enough after I bought a new timer, it stilll didnt work, I looked here and checked the lid switch and the cheapy little plastic tabs hold ing together had broken. I was able to hold it together so the washer could drain out. thanks for the tip :-)
Washer will not move to next cycle; has to be done manually
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. Hope this helped.
Jul 16, 2009 | Washing Machines
The washing machinge is not completing the complete cycle
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer stays in cycle and doesnt advance to additional cycle
Hi, It sounds like you timer has gone bad. Would need more of the model # ro be sure on what type timer you have.
Please let me know if I can assist you further.
Vic
Jun 05, 2009 | Kenmore 22622 Top Load Washer
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Stops during rinse cycle
Dear customer,
              We recommend the following when a washer's cycles dont advance..
  1. If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  2. If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  3. If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
For details on how to self test these parts plz refer to http://www.acmehowto.com/howto/appliance/washer/washer.php
Plz rate this solution.. thank you..
Apr 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
    966 people viewed this question
    Dan Webster
    Dan Webster
    Sal De GO PATS
