Question about Garmin GPS
Garmin Nuvi 300 does not switch on. The wrong charger was used
  • jbmd Sep 27, 2008
    Thank you for the advice. Tried charging the device in two vehicles but would still not operate. Tested the charger on another device and it worked perfectly
  • 171 Answers
1. If using the power/data cable to power your device:
  1. Make sure you have power at the source it is connected to.
  2. Check the fuse in the power cable.
  3. Use a volt meter to test the end which plugs into your device (the manual for the device should show which pins are power and ground. Make sure you are getting at least 12 volts of power. This will ensure you are getting full power through the cable and determine if the cable is faulty.
2. If using a 12 volt cigarette lighter adapter:
  1. Check the fuse in the adapter.
  2. Make sure the cigarette lighter in the vehicle has power by connecting another device with a different 12 volt adapter if possible.
  3. Make sure the metal tip on your 12 volt adapter is still connected
3. If using batteries:
  1. Make sure none of the battery terminals are still connected to the device.
  2. Try new batteries.
  3. Make sure the batteries fit tightly inside the device. This will ensure the battery terminals are not loose and you have good contact.
4. If you are powering the device on the built in lithium ion battery:
  1. If you have a power cable for the device, plug it into a power source and see if the device will power on with direct power. If it powers on, check to see if the battery is fully charged.
  2. If it is not, let the battery fully charge and then try to power it on with just the battery.
Posted on Sep 26, 2008
Will my Garmin Nuvi 40 work with a 24 volt supply ?
If you are using a standard Garmin car charger, you can connect the charger to a DC power source that can provide between +10VDC to +30VDC. The charger produces +5VDC to power the Nuvi. This can be verified on the charger label.
You can NOT connect any voltage higher than +5VDC directly to the Nuvi.
Apr 22, 2013 | Garmin nuvi GPS
My Garmin Nuvi 250 w gets stuck on the screen showing a picture connecting a computer to Garmin. I have it in my car and resetting hasn't worked. any suggestions
The nuvi is being put into mass storage mode (the mode used to transfer data back and forth to a computer). This is usually caused by using the wrong vehicle power cable.
The correct cable is Garmin part number 010-10723-06.
http://www.gpscity.com/garmin-mini-usb-12v-cigarette-lighter-adapter-for-nuvi.html
Aug 22, 2011 | Garmin nuvi 205W GPS Receiver
My Garmin Nuvi 300/350(2 years old) comes on and
I solved the problem by charging internal battery using the 120V. charger that came with the unit. I was not aware, that the cord in car was not charging my Nuvi and that it was running OK. until the battery was low and quit. I have to check this cord. Peter W.
Oct 01, 2009 | Garmin Nuvi 350 Car GPS Receiver
My garmin 200w shows garmin screen then goes black even with charger plugged in
sorry . some problem with your charger .try using another charger
Sep 20, 2009 | Garmin nuvi 200W GPS Receiver
How to replace battery in Garmin Nuvi. Battery is
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} FIRST make sure you have a Garmin charger!!
Are you sure it's the battery?
The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device. Go here for repair: http://www8.garmin.com/support/outofwarranty.html
Jul 08, 2009 | Garmin StreetPilot C330 GPS Receiver
Gps in sync mode when using charger
Wrong Charger....
Get the Garmin charger. That WILL work for sure.
I know, I did the same thing!!
Jun 02, 2009 | Garmin nuvi 260W GPS Receiver
Charging doesn't display map when charging
I learned that with the unit off - hold the on button down - don't release it. A PRE-BOOT MODE message will appear at the bottom and may flash. Continue holding down the start button. The first time I did it a series of dots came on the screen and I was instructed to touch each one. After that it started as normal. I plugged into a wall charger and but git the pc and nuvi icons again. I repeated the process - holding the on button on and let the PRE-BOOT MODE appear and kept holding but this time a different message came on and then the PRE-BOOT MODE appeared again. I let it go and took the unit to my car and plugged it into the Garmin car charger and it worked as it used to - normal. However, when I plugged it back in the house to the wall charged I got the pc and nuvi icon again. It appears that I am using the wrong wall charger as a previous writes stated. But the nuvi still worked in the car plugged into the nuvi charger. I hope this helps.
Jan 24, 2009 | Garmin Nuvi 660 GPS Receiver
I can't get my nuvi 300 to turn on. Can it be locked somehow? Any help would be appreciated.
Jim,
I wrote the wrong model...it is the nuvi 200. I do not see an antenna or any kind of button other than the on off control. Where would I look?
Thanks!
Angela
Sep 30, 2008 | Garmin GPS
GPS Logo
153 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
