Question about Ricoh Aficio CL7000 Laser Printer
Installation driver for Ricoh Aficia CL7000 laser printer
A friend has given me Ricoh Aficia CL 7000 laser printer. Where can I get the installation driver? Please advise.
Thanking you
    Problem Solver:
  • 9 Answers
Go to www.ricoh.com, usa, downloads and then select your printer in the drop down windows, lastly choose your operating system. now just unzip the file and install
Posted on Dec 19, 2008
On the Ricoh cl 7200 there is an error code sc386. What is it?
sc386 = an error with the black developer. This could be caused by something in the DV unit itself, or the black toner. If you've just replaced either one of these recently, try reinstalling them and resetting the machine. Otherwise, the black development unit probably needs to be replaced.
May 20, 2010 | Ricoh Aficio CL7000 Laser Printer
Ricoh Afficio cl 7000 sc 552 code what is it?
Try the procedure below. Its a hardware error on the device
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arror to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
The error code is now cleared.
Aug 18, 2008 | Ricoh Aficio CL7000 Laser Printer
I have replaced the fuser unit and fuser oil, and still getting streaks different places on the paper. Ricoh Aficia CL 7000
One or more of the drum units or the transfer belt cleaning blade is bad. Only way to tell is to remove each drum and check the surface for the toner "streaks". You can also pull out the transfer belt and check the surface for the streaks. It will be one or the other. Now if you streaks are of a particular color then that points more to the drum of that color.
Jan 06, 2010 | Ricoh Aficio CL7000 Laser Printer
I KEEP GETTING AN ERROR ON MY RICOH CL 7000 THE ERROR READS SC 221-2
SC No. Item Definition Possible Cause Related
SCs Troubleshooting Procedure Type
SC 221 Synch.
detection signal
error 2
221-001: Y
221-002: M
221-003: C
221-004: K
Main scan length detection is
not properly completed ten
consecutive times.
The front (for C&M) or rear (for
K&Y) laser synchronizing
detector boards are used for
the main scan length
detection, which automatically
corrects the main-scan
magnification.
• Damaged or
disconnected cable
between front (C&M)
or rear (K&Y) laser
synchronizing
detector board and
the LD unit
• Incorrect installation
of front (C&M) or rear
(K&Y) synchronizing
detector board (the
beam does not target
the photo detector.)
• Defective front (C&M)
or rear (K&Y)
synchronizing
detector board
• Defective LD unit
After doing any of the following, print ten
jobs or more to see if the same SC code
is displayed:
1. Turn the main switch off and on.
2. Check or replace the cable
connecting front (for C&M) or rear (for
K&Y) synchronizing detector board
and the LD unit.
3. Check or reinstall the front (for C&M)
or rear (for K&Y) synchronizing
detector board.
4. Replace the front (for C&M) or rear
(for K&Y) synchronizing detector
board.
5. Replace the laser optics housing unit.
6. Replace the BCU.
If a synch. detector board cannot be
replaced, do the following as a
temporary measure:
• Disable main scan length detection
Sep 15, 2009 | Ricoh Aficio CL7000 Laser Printer
Installed XP printer driver for Ricoh CL7000 5c
during the installation you have to select this option, by default the duplex option is not selected. Uninstall the software, restart your pc and install the software again, and select the duplexing option. I hope this helps
Sep 03, 2009 | Ricoh Aficio CL7000 Laser Printer
RICOH CL7000. SC372
You Have a cyan developer problem They come in kits which is the cheaper way to buy them. -Carl
Jul 07, 2009 | Ricoh Aficio CL7000 Laser Printer
Dirty copies on Ricoh Aficio CL 7000 copier
Did you replace the fusing oil as well? toner will not fuse well and deteriorate your new fuser very quickly if you are out of oil
Feb 03, 2009 | Ricoh Aficio CL7000 Laser Printer
Network printer installation problem
Are you using the proper Windows Vista Driver? You can't use the XP version...here's a link to the download page:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/cl7000/cl7000en.htm
Jul 11, 2008 | Ricoh Aficio CL7000 Laser Printer
Ricoh cl 7000
To my understanding since this model is a print server by itself, should you want to connect it straight to a laptop and not through a hub or router, perhaps you can try using a cross-over cat5 networking cable instead of the regular straight through.
Additionally, the IP adds of the printer and laptop should be near (192.168.15.16/printer and 192.168.15.xx/laptop).
Alternately, the printer will allow also connections by parallel, USB and bluetooth.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 14, 2008 | Ricoh Aficio CL7000 Laser Printer
Ricoh Aficio CL7000 Laser Printer Logo
157 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
