We recently retired a Win2k3 server and moved all of the shares to a Win2k8 server. Since that time, both of our Konica/Minolta copiers cannot scan to the SMB share on the Win2k8 server.
Mite want o check the IP address there where more than likely set as static. Can the copier be pinged? Also ensure all the folder s at stilled shared.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: konica minolta Bizhub C350. Following message
Hi katienash,
C-0F36 on the bizhub C350 means the machine has registered a really low toner density in the Black
Imaging Unit. I'd take the unit out, give it a shake and pop it back in. Also worth checking you have some Black Toner in it.
Good luck
Regards
m-press.biz
SOURCE: Have a Konica Minolta Di2510 copier. Need to
Im going to list in order the buttons you have to push.
You can delete the number completly or make it any number you want to. Hope this helps.
