Where do i start to fix it
Start with the fuse and if fuse is not blown check to make sure the CC circuit is actually turning on (cruise light when you arm the system) this will confirm you have power. If none of that backtrack to see where power stops. The CC is normally a vacuum controlled system so check under the hood an look for loose or disconnected vacuum lines to the CC unit.
On
this case, to troubleshoot this problem, there are solved help links. Click the
link directly and refer the details to solve this problem yourself, with help
of diagrams: ------
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working.html
Horn
and cruise control not working on Plymouth Grand Voyager?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-not-working-on.html
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working-on.html
http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
http://technoanswers.blogspot.in/2012/02/cruise-control-stop-working-on-1994.html
http://schematicsdiagram.blogspot.com/2011/12/cruise-control-not-working.html
These
will help.
Thanks.
http://technoanswers.blogspot.in/2012/02/ford-ranger-cruise-control-not-working.html
Horn and Cruise control quit working?
Horn and cruise control not working on
Horn and Cruise control quit working on 2003
Jaguar S-Type?
Cruise
Control stops working, Excessive cranks to start the engine and RPM goes max
2500
Cruise control stop working on 1994 Ford ranger?
Cruise control not working?
1996 Ford Explorer: Cruise Control Wiring
Diagram?
http://schematicsdiagram.blogspot.in/2012/06/1996-ford-explorer-cruise-control.html
These will help.
Thanks.
-----------Horn and Cruise control
quit working?
working on car?
quit working suddenly?
Cruise control stop working ?
ford ranger cruise control not working?
http://technoanswers.blogspot.in/2012/02/2005-ford-ranger-cruise-control-not.html
My Cruise control not working?
This troubleshooting help links will help you to confirm the problem.
Thanks.
