No Picture on Wharfedale tv
My boy said it went bang and smelt hot, now it turns on, but no picture, the sound works, so I would guess it`s terminal as its quite old.
  • Anonymous Mar 21, 2009
    I have a philips model 55pw9363/17f jan 2004 tv. has great audio but no video black screen. checked fuses all good. when i purchased set at sears i brought it home and found same problem on first set, i returned and got this set working great up to this point. any help appreciated.
    Brigadier General:
  • 6,966 Answers
Appreciate the direct "Ask Me".
Your son's description of "...bang and smelt hot..." could indicate a number of possibilities:
  • power supply section;
  • vertical section;
  • horizontal section .
Since it has still sound, then the power supply is a least likely possibility. The "...bang and smelt hot..." is also significant. It tells us that we can visually check which component burst and burned by opening the rear of the unit for a look and see. Further diagnosis would of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 27, 2008
Wharfedale tv
That sounds like the backlight is switching off. It might be faulty. If this is the case the screen still shows a picture but it's not lit, all black.
May 09, 2014 | Televison & Video
Sound , but no picture
It sounds like the problem is in the circuit board. The TV should go in for professional repair - electric shock is no fun. Good luck.
Apr 08, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Picture turned green, then went all pink????
It sounds that there is loose solder terminals to the terminals of Chroma IC. Re solder all the terminals by applying a little more solder to each terminal. In practice, it will be very difficult to detect these type of loose solder points. The only way, is to re solder all of them at one time.
Oct 16, 2012 | Toshiba CZ36T31 36" TV
Have 1080dlp sound but no picture
DLP type sets regardless of brand all have some things in common--use a lamp, a Ballast, etc.
If sound you need to see if the lamp is coming on when set is turned on--usually in these type sets if no brightness one or more lights on the front of the set will be blinking---no model number is indicated with this question..
May 19, 2012 | Televison & Video
Wharfedale LCD3210HDAF blank screen
Wharfedale LCD3210HDAF this tv was working fine the night before .. when i turned it on in the morning the screen came on then instantly went blank .. although the sound is fine i am unable to get any on screen including menu an volume information and of course can any one help ??
Oct 27, 2009 | Televison & Video
TV Picture Pops In and Out Toshiba Color TV CZ27V51
mine was doing the same thing. If i put pressure on the cable input from left or right it would fix this.
May 22, 2009 | Toshiba CZ27V51 27" TV
My wharfedale lcd42f1080p just went bang when plugging it in!!
Sounds like something else in the power supply. The surge inrush current could have blown the bridge rectifier. (device which changes AC to a pulsating DC for the power supply). You may need to have the power supply serviced or replaced.
Apr 15, 2009 | Televison & Video
My 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
A shorted horizontal output transistor or shorted flyback. If the flyback is shorted replace also its HOT.
Apr 05, 2009 | RCA F36650 36" TV
Progresive scan problem and didn't get picture in tv
Our problem was that we could not get picture on the tv screen but it got sound.We tried to solve it using different techniques like the setup,video source,function keys pressed on remote control by trial(only assumed) and error as we could not see the screen and I used scart with every conection but three point pin was free so I put only one pin in video out put and at that moment I could see the picture on tv.
Jan 30, 2009 | Wharfedale DVD-M3 DVD Player
No picture
unfortunitly sound is one circuit ,,while all the rest makes a picture. hearing a bang could mean a capacitor exploded, your fly blew up..or even you lost a tube. you need a tech. good luck
Aug 15, 2007 | Philips 60PW9363 60" Rear Projection...
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
Electro Med Services...
