At firt, the washer would take 2 hours to wash clothes and then it started to take longer and longer. Sometimes the washer would make funny noises.
  • jamielynn315 Sep 30, 2008
    Well, we now think that it's the switch that is causing it to be slow..It would stop after every cycle. It would stop after it got done washing and would stop after the rinse cycle and it's the same with the spin cycle. It did that until one day it just wouldn't spin at all.
  • 99 Answers
Turn off the water to the washer. Remove the hoses from the back of the washer. Carefully remove the little filter screens from the hose connections in the back of the washing machine. Clean and replace them. Your laundry should be done is less than 20 minutes now.
If it continues to make funny noise, write back.
Posted on Sep 26, 2008
Frigidare affinity model # atf6000es won't spin in
sometimes in the bottom right hand corner of the machine there is a little face plate and allows to you unclog foreign material that collect over time.
Nov 06, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
What would make my washing machine leak water and make a funny noise?
this sounds like the main bearings have worn out (they start to rumble first) when they start to brake up they rip apart the water seals that are between them and the back of the washers drum, and then it starts to leak water, to test them to see if there claped out,,,, open the door and try lifting the top of the drum lightly , if it lifts a bit then drops back when you let go its the bearings going, now spin it by hand and you will here a rumbleing noise or grinding noise, when the washer is running on spin it will sound like the end of the world is coming???? im sorry to tell you this part is not cheep to fix, its 2-3 hours work?
Oct 22, 2009 | Kenmore Washing Machines
Washer doesn't spin, just makes funny noise.
i would change the coupler between the motor and transmission....
Jun 23, 2009 | Whirlpool Washing Machines
Front load washer makes funny noise when pump turns on
The pump sounds like it may be plugged wih a coin or something like that. If the pump is plugged it will make a funny noise. Remove the pump and clear everything out of it
Jun 07, 2009 | Frigidaire Affinity ATF6000F Front Load...
Moisture in dryer
is it cold outside clean your vent run dryer with out vent on gas dryer?
Feb 24, 2009 | Maytag LSE7806A Top Load Stacked...
Not working-push button controls-do not work correctly-sometimes
You need to replace your user interface board. Always order with the correct model number on the unit. This will eliminate you issues
Jun 07, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
Loud squeaky Noise
this is not 100% diagnosis as can't listen to noise but fault may be bearing lip seal disintegrating which is a serious fault and if im right then bearing will shortly go as well. reason it is noisy during start is that seal is dry and gets wet when full of water
Apr 18, 2007 | LG WM-2277HW Front Load Washer
Machine runs, but clothing won't dry
It sounds like your heating element is shot. The elements on this machine are very sensitive and if you use too much cleaning fluid the part will wear down after a while. You will need to get the part replaced (yuck) and start to use a little less washer fluid. Please let me know about your experience with the company (
Sep 16, 2006 | Malber WD1000 Front Load Washer/Dryer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
