I am trying to install an HP 7460 wireless printer to my HP cpu via a linksys router. My password for the router is 7 letters, and the printer says it has to be 8 letters. How do I change the router password? Wireless-G Broadband Router model WRT54G2.
  • 36 Answers
When accessing the router’s web-based setup page, a log-in screen will appear asking for the router’s password. The router’s default password is “admin.” You should change the password for security purposes.
The router’s password must be changed to:
  • Prevent unwanted users from accessing the router’s web-based setup page.
  • Enable Remote Management.
The router’s IP password can be changed by:
  • Running the router’s setup CD.
  • Changing it on the router’s web-based setup page. For instructions, please follow the steps below.
Changing the Router’s Password
Step 1:
Access the router’s web-based setup page.
NOTE: If you are using Mac to access the router's web-based setup page.
Step 2:
When the router’s web-based setup page appears, click Administration.
Step 3:
Enter the new password on the Password and Re-enter to confirm fields.
Posted on Sep 26, 2008
Trying to connect hp printer to wrt150n
there are many ways to connect your printer with your linksys router:
connect your printer via ethernet cable.
connect your printer to the router via usb cable.
connect your cable to the router via wireless network
so if you are trying to connect your printer router via wifi method. then you need to go to setup on your printer and then go to wireless network option, once you will reach there then you will see there your network name and password you need to fill that network name and password on your router and then hit connect your printer will connected to the wifi.
if you have any kind of problem with any steps or you dont know your wifi password then you can contact to our helpline number :
Mar 10, 2014 | Linksys Wireless-N WRT150N Router
How to set router password
Make sure that you are connected via ethernet cable or hard wired connection:
1. Open a browser ( internet explorer, mozilla firefox,google chrome or safari)2. Delete all of the characters in the address bar3. Type the numbers 192.168.1.14. Press enter.5. You will be able to view the modem settings page.6. Select Basic Setup or the second tab with the word interface.7. Select Wireless Setup8. Enter the SSID or (service set ID), this will be your wifi name.9. Select WEP or WPA for your router's wi-fi password.10. Select ASCII for the passworrd.11. Enter any password ( around 10 alpha numeric characters to make sure that it is a strong password)**alpha numeric means combination of letters and numbers.12. Select Save or Apply.13. Disconnect the network cable for you to test the Wireless password connection.14. Scan for new wireless network on the lower left hand of your computer's screen.15. Look for the wireless name that you entered for your SSID.16. Connect and it will ask you for the wireless / pre-shared key17. Enter the WPA password that you created ( the 10 letters and numbers that you entered for ASCII)18. Press connect.
there you go... you will be connected to your router via wireless with password protection. No one can connect to your router unless you gave them your PSK or wi-fi pre-shared key.
Dec 24, 2011 | Linksys Computers & Internet
Connect HP 1102w to Linksys wrt54g
Hi! I was able to see that you've got a wireless printer. If you need to connect this to your router, this works like connecting a laptop wirelessly. First, you need to know your wireless name (SSID) and your password (WEP/WPA key). In case that you did not configure your SSID and password, it could be found on your router's sticker. If you were able to configure the two, then you just need to enter it when your wireless printer would ask for these info. If you needed help in configuring your router, I have here a page that you can follow just in case. Please visit http://www.columbia.edu/acis/networks/aptnet/linksys/index.html. This would help you on how you can set-up your router. In case this won't work, you may need to remove the printer's driver from your computer and reinstall it.Try to print a document via USB, just to make sure that it's working, then you may proceed in reconnecting it wirelessly.
Aug 06, 2011 | Linksys Wireless-G WRT54G Router
Router does not show wireless light. I have reset it but can't access it with the setup wizard. Any suggestions?
* NOTE: If you tried to set-up the WRT-150N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
then do this :
1. Hook up the Linksys WRT-150N Router to the Modem via a LAN cable.
2. Hook up the Linksys WRT-150N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-150N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-150N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-150N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys Wireless-N WRT150N Router
Need cd for downloading program
Assuming you are trying to install a router.... routers do not use drivers or software. CD's provided with Routers are generally used to walk you through the installation/setup process. Most Linksys routers are default accessible at 192.168.1.1 via your browser. the default username is admin and the password is usually admin. If this does not work, try resetting the router by pressing the rest button located on the back of the unit (small hole) with a paperclip. hold the button in for about 1 minute and then release it... If you are unlucky enough to have a unit with a flashing power lite, this is a dead unit and is not repairable. Look up your model for more specific instructions on www.linksys.com under the support section.
Apr 12, 2010 | Linksys Wireless-G Broadband Router
Trying to set up LInksys WPS54G, connected as
by default ip address of linksys is 192.168.1.1
to star config you need to be connected with ethernet cord rj-45
or conenct via wireless by conencting to linksys on wireless
admin user: blank
admin pws: admin
*choose a protocol on your linksys router on internect conenction type:
check isp protocol :
dhcp: needs serail number of mac address
it picks up automatic
pppoe: needs username and pws from isp
*the ip address has to be diferent from the isp modem:
isp modem 192.168.1.1 linksys 192.168.1.1 incorrect
isp modem 192.168.1.1 linksys 192.168.2.1 correct
change the ip on lan settings on your router
*wireless: ssid by default is linksys
ssid: linksys
wep : none
to setup wireless
access the wireless basic
change the ssid to any network name
enable the wireless password
choose wireless security
enable wep key 10 digit hex pws
make shure you saved settings on every settings
Feb 12, 2010 | HP LaserJet 1320n Printer
I am trying to connect my laptop to my hp printer
It's the password you used to setup security in your wireless router.
Feb 02, 2010 | HP Officejet Pro L7680 All-In-One Printer
My linksys srx200 doesnt seem to be responding to my laptop when
Try to reconfigure the printserver using the setup CD that came with it. Normally that will fix the problem. Make sure the driver of your Printer is installed first before running the printserver setup.
Jun 13, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Hpj4680 won't connect wireless to network,
I had the same problem , I entered the configuration of my linksys router and changed from mixed to B+G in the wireless tab and after that, no more problem, it connected rigth away
Jan 04, 2009 | HP J4680 Office Jet All-In-One Printer
608 people viewed this question
jasbo
jasbo
