Question about Whirlpool GHW9400 Duet Washer
Whirlpool Duet GHW9400PWO, Front Panel comes off
The front panels of our Duet washing machine are coming off. Please have a look at the following picture. Could you please let me know what the part number of the fasteners is? It feels like one of them snap in fasteners. I can push it the panel in but within a few seconds it snaps out again. Could you please let me know what needs to be done to replace them.
In advance, thank you very much for your help.
Tom16
  • 5,911 Answers
There are no fasteners that I know of. I've worked on this model numerous times and have never seen any. There should be screws holding the front panel in place. Remove the lower panel under the door by removing the screws under the bottom edge. HINT: Placing a block of wood under the bottom of the frame to elevate the front feet of the washer off the floor will make it easier to access the screws. The washer is heavy so it may take two people to do this. DO NOT push on the door or the control panel. Use the facing of the washer front panel for leverage. With the screws removed, the panel will drop down, then come off. There should be a mounting screws for the front panel on each side of the washer. Make sure the screws are present and that they are tight. You may just have a screw loose (no pun intended). I hope you find this information helpful. Let me know if you need further assistance.
Posted on Sep 27, 2008
How do i reset front panel on my whirlpool washer front load duet
Hi
Its a simple procedure to reset the Whirlpool Duet front load. Please press and hold the END OF CYCLE button for 15 seconds to reset. Please get back to me if you have any other questions.
Kevin
Nov 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hello, I have a whirlpool duet washer, modelwfw9200sq. It is leaking. We had a repair person fix this last year ( just a small rubber tube comes loose) Can you tell me again where this was located on...
Front - bottom. You must remove the front kick panel to view.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 28, 2010 | Whirlpool WFW9200S Front Load Washer
Front loadin washer says control locked!
The Control Lock is a designed safety feature that enables the us to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds to 10 seconds.
Please do refer this link for a detailed explanation for your knowledge.
http://www.fixya.com/support/t4186517-control_lock_light_machine
Apr 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Take off whirlpool duet front panel for filter
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
Dec 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leak
Hi, If you remove the lower half of the front panel, you will be able to see the pump and hoses. Another option is the bellows around the door. Please let me know if this helps or if I can assist you further.
Thank
Vic
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a front loader whirlpool duet #ghw9100lw2
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Apr 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet
you can remove the lower access panel of unit ( 3 screws across the front bottom of unit), behond there directly in the middle of machine yuoll see large plastic turn screw. that s teh pump housing "filter cleanout". unscreww and clear all debris. be aware however if theres water in machine it will come out on you when you release teh turnscrew
Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Repair washer
hi thanks for the question the front panel comes off 2 screws at the bottom remove 3 screws at back of top remove top pull towards you 2 screws at the bottom of front this should take the front off thanks please accept and a positive feedback please thanks the appliance doc
Sep 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
97 people viewed this question
Dan Webster
Dan Webster
prem mathew
