15 sq yards of carpet is equal to how many sq meters
SOURCE: conversion of 1900 sq. foot to square meters
An area of 1,900 square feet is equal to 176.52 square meters since there are 10.7639104 square feet in 1 square meter based on 3.2808 feet in 1 meter.
Alternately, there are online converters for most measurements.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: in algebra formula,,,,carpeting cost $20.00 sq. yd
Here is the Solution:
1. Convert 15 ft into yards. 1 yard = 3 feet
=> 15 ft = 5 yd
2. Find the area of the given room. The cost for given room is given, and cost for carpeting 1 sq. yd is given. So,
800/20 = 40 {i.e. 40 sq. yd (area of the given room)}
3. Now, Length * Width = Area
=> x * 5 = 40 [Taking Length = x yd]
=> x = 40/5
=> x = 8 yd
=> x = 8 * 3 ft
=> x = 24 ft
So, Length of the given room is 24 ft (8yd).
I hope this solved your problem (in time).
SOURCE: how to convert cbm into
Now cubic meter calculator can be defined as a
simple device which is used to convert a given value in meters to it's
corresponding cubic meter form. Other than this we can always add the
formulaes of the structures to get the volume of the structure by
simply entering it's side length or height etc..
Let us consider simple examples :
Suppose
that we have to convert 5 meters to its cube. The only thing we would
do is that we would enter this value of 5 in the calculator and
calculator with do the calculation as and will show the result to you as 125 .
Now if we have added formulaes to this calculator , like for
calculating the volume of cube,cylinder and cone (say). Then we can use
this calculator in three different cases.
Visit anthony's tuition class. Specialist in H2 Physics Tuition and H2 Maths Tuition.
