Question about Eureka Vacuums
The beater brush on my vacuum appears to roll when I turn on the vacuum however, you only hear the actual sound of it on occasion and the vacuum is not vacuuming thread off the floor.
  • Anonymous Mar 27, 2014
    My vacuum brush will turn until you put it on the floor
  • 438 Answers
Greetings from GoVacuum,
Your belt has probably been stretched to a point, the brush no longer spins when it touches the carpet. You probably can turn the machine over, and see the brush spinning, but it's probably stretched to a point where as soon as the agitator brush begins feeling any resistance created by the carpet, it just is not enough tension to spin the belt.
Replacing the belt of your vacuum cleaner will most likely need to be replaced. Even though the belt might not be broken, we do recommend that you replace the belt every 6-12 months to ensure optimal performance.
Usually you can find manuals on how to replace the belt, and what type of belt you will need in your owners manual (most manufacturers have these manuals available on line as well).
Chris Jones
Posted on Sep 29, 2008
  • 37 Answers
Your belt is probably so loose it cant spin your brush when it hits the carpet.
Posted on Sep 27, 2008
D.C. 17 makes a loud whining noise when beater brushes are engaged. Normal sound until then. Replaced belt. Still so loud it hurts my ears!
Could be the brush roll, remove brush roll and see if noise is still there when brush roll motor is running.
Sep 18, 2017 | Vacuums
The brush quit turning
Sounds like 2 separate motors. remove the beater bar and see f that motor turns without any load. Of not time for a new beater bar motor.
Dec 22, 2014 | Vacuums
How do I dissassemble the beater bar?
It's fixable if you don't wait too long. Dirt and hair get under the end caps of the brush roll causing friction which causes heat which can damage the vacuum nozzle housing. If the housing isn't damaged you may just need a new brush roll and new belt.
Jun 18, 2017 | Bissell Upright Vacuum - The Pet Hair...
My dyson animal is hard to push on carpet - the beater bar is still operational. When I turn off the beater bar and run the vacuum on hardwood the beater bar stops moving, but it still ''rolls'' on the...
If suction is not what it was, check all of your hoses and connections for vacuum leaks. And the beater roll should always be turning - check out the belt for slippage.
Sep 20, 2017 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a Hoover Savvy Bagless Upright. The beater bar does not turn. It does not appear to be the belt.
The Savvy has a brush roll motor, whcih could be bad. There also is a circuit board near the brush roll motor, a circuit board underneath the tool holder, and the switch asm. in the handle. Any of which could be the cause of the brush roll not turning. Just needs to be checked to find what is causing the problem.
Jun 11, 2008 | Vacuums
Wind tunnel supreme sounds very loud
Sounds like a bad motor, you have a years warranty on this, take it in for warranty repair. You will void the warranty if you mess with it.
May 08, 2008 | Vacuums
Beater bar
You may have a bad switch, one part of it is not turning on the brush roll motor. It could also be the brush roll motor.
Feb 08, 2008 | Clarke CombiVac 12 Bagged Upright Vacuum
Beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Jan 12, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
122 people viewed this question
Top Eureka Vacuums Experts
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
