I am connected to my wireless network from my advent 4211 notebook, but I am not receiving any packets back from my dlink dkt-710 router. If I configure the internet protocol to automatically obtain ip address etc. it will not even connect to the network, so i have to assign an ip address etc. ps. the notebook is running windows xp home edition. It's driving me nuts. By the way, the wireless card in the notebook is DEFINITELY on, and there are two other machines running off the router wirelessly, one xp and one vista, that work perfectly fine (including the one i am sending this message on). I have even performwed a winsock fix. any ideas????
    Scholar:
  • 174 Answers
FIRST you check for any security options enabled - like password or in the wireless advance settings you pefer to connect only to this network = make that to any wireless access point. The computer is sending packets but return packets will only comes through filters like firewalls or security measures definetly your problem belong to the security settings with your pc which is not accepting any outside devices to connect - check your firewall setting and under network properties check internet protocol settings also check your antivirus blocking the connection try to ping the wireless adpater ip of your pc by itself are your getting the reply???
Posted on Sep 26, 2008
ADVENT 4211-B KEEPS DROPPING WIRELESS CONNECTION
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls, mirrors, fish tanks and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Apr 06, 2013 | Advent 4211c Notebook
Vista have new router wireless network shows connected but not receiving packets
The problem is might be your computer is CONNECTED,but there are no network activity so you're receiving no packets
If you can't connected to the internet,then that network probably doesn't has an internet access on it
Aug 26, 2012 | Acer Aspire 7720-4428 Notebook PC
Netflix update asking for ssid no.
SSID - Service Set Identifyer
The SSID is a secret key which is set by the wireless network administrator. You must know the SSID to connect to a 802.11 wireless network. However, the SSID can be discovered by network sniffing/scanning. By default, the SSID is part of the packet header for every packet sent over the WLAN.
go in your dlinks settings it by default always set to the routers name, you computer should detect the router in an area of networks, if the update is looking for an SSID # look on the sticker on the router it should say it there
Jun 06, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Laptop cannot aquire network address from wireless router
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Make sure that the DHCP server on the router is enabled
Click Here for step by step solution
Apr 30, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I have a dlink dkt-110 and have no idea how to secure it without loosing it
Are you trying to secure the wireless network then you will need to access the router setup.
Is there any computer connected to the router?
If not then you will need to connect the computer to the router.
once you open to the router setup, you will see the option of secure the network.
Click here for more info
Dec 03, 2009 | D-Link 802.11g Wireless Router WBR-1310...
My Advent 4211 netbook connects wirelessly to the Internet through my Desktop and a Belkin router. How do I allow the netbook to see the files in the desktop?
if you ran your network wizard to get the internet access shared then you should be able to share your files too.
and folders the same way ,
go to my network device,
veiw network computers,
if you can see the computers desk top then
go to Shared folders and try to see if your folders have been shared open something.
If you can see the desktop and not open the shared folders then run the network wizard again,shutdown and restart,to save your settings,
to share files between both machines you will need to drag the file into my shared folders or rightclick on the file your sharing and click on sharing,follow the prompts to share and that should fix your problem.
Please rate me thanks MISTERDJ
Aug 16, 2009 | Advent 4211c Notebook
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
