Question about Brother MFC-8860DN All-In-One Laser Printer
Did u fix the MFC-8860DN clicking sound?
Hi, Did u fix the MFC-8860DN clicking sound? If so, what was the problem? I have the exact same problem.
Thanks in advace,
SQKULALY
  • Anonymous Jan 08, 2009
    Mine is doing the same.
We had this problem too. After checking to make sure the paper tray was locked in the correct position and trying to print, I noticed that the printer itself had pulled out the paper tray so the back was not flush. After looking at the paper tray to see what the problem was I noticed that the paper tray would not lock in the correct position. If you look at the paper tray there is a vertical row of little teeth that the lock "catches" on. On our tray they are worn down and broken in a certain spot, so the latch cannot catch on them. The clicking noise comes from the paper tray's latch trying to latch and then failing or fom the latch being slid forcibly past the teeth on the paper tray. When I took the paper tray out and wiggled it past the worn down area it made the same noise, only less loud since it wasn't inside the printer, which amplified the echoes.
Posted on Apr 13, 2009
Sephiatone has the best solution. I checked all the gears and they are fine. Next I will clean the rollers, but I wanted to isolate the fix first. The arrow in the tray for the paper size is supposed to line up perfectly with the mark. If it does not, it will click/pop. Mine was off about 1/8 of an inch. Make sure you unlock the tray with the slider button on the top of the back of the tray before adjusting. Make sure you lock it back after you adjust the paper size.
Posted on Nov 19, 2011
  • Rickaroo Nov 19, 2011
In our case, we heard clicking and a smelled a slight burning smell. What happened was that the back part of the paper tray was sticking out a little too far (as if it had accidentally been unlocked and slid out.) This is referring to the back paper adjustment. It wasn't sitting flush w/ the 8.5X11" paper, so we adjusted it to where there was no gap at the back of the tray, re-inserted, then the printer/fax is working again. Now, I'm on this site trying to figure out how to replace the PF kit. Overall, in our case it was a simple fix, but we had initially thought that loud clicking sound was the death of our 8860DN. I'm sure it did put a little stress on the motor while we were trouble shooting, but I'd check the paper tray to make sure it's completely flush w/ the paper you are using and don't overfill it.
Posted on Jan 08, 2009
MY BROTHER MFC-8860DN IS LEAVING "GLOBS" OF TONER ON THE SHEET WHEN IT PRINTS. CAN THAT BE FIXED?
Hello. this error is caused by the "drum". the drum can be replaced either through Brother or your local office supplies store.
There is no quick fix for this issue.
Regards GM
May 30, 2011 | Brother MFC-8860DN Printer
Scan and copy modes inop
try resetting the machine by unplugging it for an hour, and then start it back up. Next go to the menu, and reconfigure your fax settings.
Feb 25, 2008 | Brother MFC-8860DN Printer
There is a loud clicking sound that comes from the drawer and the paper won't pull through. MFC 8860DN
You can check if the paper guides are set properly by depressing the purple lever on the right front of the tray. The leading edge of the stack of paper should rise out of the tray. If the paper cannot rise, or rises unevenly, you need to adjust the guide on the tray. There should be between 1/16 and 1/18 of play from front to back for the stack of paper in the paper tray.
The loud click sounds alarming, but is not the problem.
Sep 02, 2010 | Brother MFC-8860DN All-In-One Laser...
MFC-8860DN Printer: i have lost my installation cd. Can I get another ...
Download the driver from the internet and install
brother website is www.brother-usa.com
Select the exact medel from the above site
May 06, 2010 | Brother MFC-8860DN Printer
Brother MFC 8860DN. ''No Paper'' error message and CLICKING SOUND
Pull the paper tray out, look in the top middle by the roller holder, you will see a black plastic lever (edge actuator) hanging down, it should be flush with the roller, be careful when pushing back in place.
Feb 01, 2010 | Brother MFC-8860DN Printer
No Paper Error
make sure you have an 1/8" gap between your paper and the rear paper stopper in cassette.
hth,
razors
May 27, 2009 | Brother MFC-8860DN Printer
Fuser replacement on Brother MFC 8860DN
Yes I did it myself, however I am savvy with most hardware, I wouldnt suggest it for the novice. It cost around $NZ245 for the fusing unit, which from doing a quick search online is about the same in most countries.
Aug 11, 2008 | Brother MFC-8860DN All-In-One Laser...
Scanning to email from Brother MFC-8860DN
you have to configure the button by help of the control center. Start control center and click settings.
Oct 10, 2007 | Brother MFC-8860DN Printer
Brother MFC-8860DN All-In-One Laser Printer Logo
1,210 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
