Question about Bosch Washing Machines
The drum won,t go around or spin BOSCH Classixx 1200 washing machine
BOSH WFL 2260 SPINS OK BUT WASHING CYCLES DO NOT WORK. FILLS WATER OK
Posted on Jan 01, 2010
    Problem Solver:
  • 3 Answers
Could be that the belt inside has come off or snapped its like a fan belt on a car. You could try opening it up and having a look. you can buy spares for most things like this at a local appliance repair shop. Usually you just loosen one end off put the new one on then tighten the loosened end back to tension the belt. hope this helps.
Posted on Sep 27, 2008
2 Suggested Answers
SOURCE: Bosch Washing Machine - Model Classixx 1200
test test test test test
Posted on Apr 27, 2010
Bosch classixx 6 washing machine drum isnt spinning and the timer is reading
Reasons that can cause this situation are
1- the drum motor is faulty
2- the drum motor relay doesn't receive power
3- The relay receives power, but relay contacts are won out hence not connecting.
There is a wire disconnected that links the motor to the timer board.
Jul 17, 2016 | Bosch Washing Machines
Bosch 1200 classixx not spinning
bosch 1200 classixx not working properly. On 12 min spin cycle it starts then after 1 min timer reads 0:01 and it stops. washing cycles run but doesn't seem to be any spin action
Oct 12, 2009 | Bosch Washing Machines
Flash from the back of the washing machine.
it sounds like the brushes have gone in the motor that turns the drum
Apr 21, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosh 1200 classixx does not finish the program, conditioner stays in the dispenser
check your filter. Could be an eratic pump. Dispening draw needs to be cleaned and make sure the small hole is clear to allow the conditioner to flow through
Feb 26, 2009 | Bosch Classixx WFL 2462 Front Load Washer
Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
Dec 22, 2008 | Bosch Classixx WFC 2465 Front Load Washer
I have cleaned the pipes going for rinsed water,plus the plumbing stuff like vertical pipe which has on top something like coupler for washing machine and dishwasher, here was problem. It was cloged up with rubish and becouse the pump could not make enugh pressure the machine has stopped in the moiddle of washing as it could not rinse.(Spin)
cheers
Sep 23, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch classixx 1200 express
Not a programme error but carbon brushes on motor.Fixed by local engineer.
Aug 30, 2008 | Bosch Classixx WFC 2465 Front Load Washer
My bosch classixx 1200 express
Close the door and turn the dial to drain
Jan 11, 2018 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
629 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
