Question about Amana Comfort Zone 18M33PCEH Air Conditioner
Failure in comfort zone one
Sorry for my english,
I have installed at home a comfort zone one of Carrier AC and some days ago suddenly didn´t work.
I select the option COOL AUTO, and can see in the zone controller the correct secuence(FAN and COOL) but the AC doesn´t work.
I get the installation instructions manual and follow instructions but all that it say are working ok.(leds on the relay pack are indicating the correct relay closed and voltage is 24 vac).
Could you help me, please
Thanks a lot.
Bay
  • 1,711 Answers
Check the drain line. Possibly tripped by the float switch.
Posted on May 10, 2017
  • Amana Master
  • 10,137 Answers
There is a capacitor connected to the motor on the compressor. If it fails, the motor won't start and the safety thermal cutoff will stop voltage at the motor terminals. There are fuses inside the power interrupt box on the side of the outside unit. One of them may have blown
fwadley
  • 482 Answers
SOURCE: carrier comfort zone II (Zonecc (2,4,8))
replace the thermostat
Posted on Nov 28, 2007
farfield
  • 462 Answers
SOURCE: Carrier Comfort Zone ii - trying to find user manual
Your description leads me to believe you have 2 thermostats. How long have you lived in the house? Did it work for you lately? Sometimes its just the door switch. If you have to remove it to change the filter or had it off for another reason hold the switch in by hand and try it. then check the door for correct channeling in the grooves provided and see if this is it.
Posted on Mar 10, 2009
  • 38 Answers
SOURCE: Carrier Comfort Zone 2 flashing E2
the e2 error on your thermostat is a problem with the return temp sensor on your system, the only thing you can really do is call a company and replace it, you can't bypass it or remove it cause the system wont run properly
Posted on Jun 30, 2009
  • 26 Answers
SOURCE: Amana Comfort Zone will not turn on.
Power coming from circut board? If yes, check the capacitor. Low voltage fuse good? Transformer good?
Posted on Jul 13, 2009
james3751
  • 614 Answers
SOURCE: Noisy Amana Quiet Zone air conditioner
The compressor sounds like the springs inside are bad. You can live with this are get the compresor eplaced if it is over five years old buy a new unit. Compressor will cost more than a new unit. Russ
Posted on Jul 19, 2009
Our Carrier Comfort Zone II thermostat, which has 2 zone readouts, currently shows a temperature of 00, as in zero zero, on one zone. That is the main zone for our home. Zone 2, for spare bedrooms, etc....
This .pdf file may be of help to you:
www.brivis.com.au/.../Carrier%20Comfort%20Zone%20II%20Owner's%20Guide.pdf
Perhaps you could get some help from Carrier Support here:
http://www.residential.carrier.com/support/index.shtml
I noticed they have an option of talking to an engineer, and perhaps they could explain how to reset or set the unit.
Hope this helps.
Sep 25, 2010 | Heating & Cooling
The Carrier comfort zone thermostst displays the
Go to panal and reset control. Small reset button on control board. Let me know if it clears.James
Oct 12, 2009 | Carrier 38CKC042 Air Conditioner
We have the same problem, was hit with lightning and came up E1
You didn't get a Carrier tech. Carrier technicians only work on commercial equipment. Residential applicaitions, installation and service of Carrier residential units are done by dealers. They are not carrier owned but get buy the product at discount get training and get to show our logo. You can't fix the boards, they have to be replaced. It sounds like you have a Gen II VVT system. You can get the part via Totaline stores or a distributor. You will need to know how to readdress the other controllers to operate correctly. Use WWW.Carrier.com.
Aug 03, 2009 | Carrier 38CKC060 Air Conditioner
Shopping for a new AC. Looking at Carrier Comfort
For the money might want to look at a ruud or reem carrier is just kind of higher in price and the warranty every manufacture carries at least 5 years on the compressor hope that helps shop around do your home work and remember any unit is junk if not properly in stalled. good luck Tom
Jul 06, 2009 | Carrier 38CKC036 Air Conditioner
Blank readings on Carrier Comfort 3 zone thermostat
The stat that works is called the main and the other two are called slave stats. The stats must be set to heat or cool the same as the main. If you want one room to cool and one to heat , sorry. Need to upgrade to auto changeover. Is this AC actally a Heat pump?
Jul 01, 2009 | Carrier 38CKC042 Air Conditioner
Carrier Comfort zone 2 is flashing e1 after a storm/power outage
HEY THERE, DID YOU TRY POER CYCLING THE UNIT? TURN IT OFF AT THE BREAKER THEN BACK ON
SETH
Jun 27, 2009 | Carrier 38CKC060 Air Conditioner
Carrier 38TXA030 not working
That sounds like a very efficient system Gratz. You can try a reset by throwing the breakers off and back on and check all your micro fuses on boards and zone controllers. GL!
Jun 11, 2008 | Heating & Cooling
Unit/control panel completely dead
Check your circuit breaker, "off" and "on" the breaker it my be tripped off. If it wont work may be some fuse blown in the control, or the control itself may be defective.
Jan 28, 2008 | Carrier 38CKC042 Air Conditioner
Amana Comfort Zone 18M33PCEH Air Conditioner Logo
50 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
